Question about HP Pavilion tx1000z Notebook
Start up for only 2 seconds and will automatically shut down
Can't find chit30gears fix.
OK SO U HEY IM SERIOUS IT WORKED FOR MULTIPLE PEOPLE IT WORKED FOR ME IF IT DIDNT WORK I WOULDN'T BE TELLING U NOW.
STEPS
- USE YOU STRONGEST ARM AND USE UR PALM
-APPLY ALOT OF PRESSURE WITH UR PALM AND PUT THE PRESSURE ON THE ENTER BUTTON.
-WITH THE PRESSURE ON THE ENTER BUTTON ANYWHERE AROUND THE ENTER BUTTON AND TURN IN ON.
- IF IT DIDN'T WORK THE FIRST TIME APPLY MORE PRESSURE BECAUSE THE NVDIA CHIP IS NOT CONNECTING TO THE MAIN BOARD SO ADD PRESSURE AND TURN IT ON.
-NOW RUN UR TX1000 FOR A WHILE TILL IT GETS WARM SO THE NVDIA CHHIP CAN ATTACH TO THE BOARD AND UR DONE!
TELL EVERYONE WHO HAS THIS PROBLEM 100% GUARENTEED TO WORK YO!!
Posted on Nov 21, 2009
My HP tx1215 was dead. I used the above techique and it worked. wow!!
Posted on Dec 04, 2009
PS3 shuts down completely and abruptly without warning and reason
Your GPU gets hot, because when u start the console it gets hot, nd when u start a game it becomes hotter, when the system detects that ur GPU is hot it shuts down Automatically, the cause of this problem is common, you need to replace the GPU's thermal compound nd try to find the The Arctic Silver one, it's the best.. GOOD LUCK
Feb 03, 2013 | Sony Playstation 3 (PS3) Console
System runs from about 3 to 15 secs then shuts down. That doesn't give me enough time to do anything in the BIOS setup when pressing F2. Then the system refuses to start (by pressing the power button)...
Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged. The computer should stay on even without an operating system or hard drive installed.
Jun 24, 2011 | Dell Precision Workstation T5400 Quad Core...
1998 Ford Windstar Minivan: 1. I sometimes get an extended crank when trying to start engine after I've made a short trip. 2. My interior lights won't go out after I turn the engine off, so I...
YOU MAY HAVE A BAD DOOR AJAR SWITCH. HOWEVER, YO HAVE A TIMER THAT SHUTS OFF THE INTERIOR LIGHTS AFTER 300 MINUTES. IT'S CALLED A BATTERY SAVER FEATURE. TEST IT OUT.
THE EXTENDED CRANK MAY BE A CHECK VALVE IN THE FUEL PUMP IN THE TANK, ALLOWING PRESSURE TO DROP WHEN YOU TURN THE ENGINE OFF.
OR A BAD FUEL PRESSURE REGULATOR ON THE ENGIEN FUEL RAIL.
TRY THIS TEST, TURN KEY TO "ON" POSITION, WAIT 5 SECONDS, SHUT OFF KEY FOR 30 SECONDS. TURN KEY ON, WAIT 5 SECONDS, THEN START ENGINE. IF IT STARTS RIGHT UP, YOU ARE LOSING FUEL PRESSURE WITH ENGINE OFF.
THIS BUILDS UP PRESSURE IF IT DROPPED DURING SHUT DOWN.
REPORT TEST RESULTS.
PLEAE RATE, THANKS
May 16, 2011 | 1998 Ford Windstar
Ps turns off straight away. was midway though a game when suddenly shut down and then when trying to restart the system, it automaticly turns off. no ejection option available ...or anything for that...
It sounds like yellow light of death. If you answer yes to these questions then thats what it is. I have a step-by-step instructions on how to fix it.
1. When you turn your console on, when it turns off does it beep 2 to 3 times before shutting down?
2. When it does shut down right before it does pay attention to the lights, do you see a yellow on blink once for a split second?
3. Afte the console shuts completely off does the red light just sit there and blink?
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Feb 25, 2011 | Sony Playstation 3 (PS3) Console
My laptop turns itself of after 3 - 5 minute
Check the charger of your laptop if there is any place that has problem or cut? check the voltage of your laptop whether is the same thing with the charger. If everything are fine, then reload your operating system, because I have noticed this problem with my clients. Good luck
Feb 03, 2011 | Dell Latitude D600 Notebook
My NN-T994SFR Panasonic Microwave shuts off after 1 second.
My unit shuts off after about 2 seconds. It seems like it tries to go, but it sounds like it stops working and then 1 or 2 more seconds run off and it shuts down. Then you hit start again and it lights up inside and then shuts down. It's only about 2 or 3 years old.Any solutions?
Mar 05, 2010 | Panasonic Microwave Ovens
The website will not let me respond to the fixes people have suggestedso far. My dell inspirion laptop will only run in safe mode. When itdoes start in normal mode it shuts down in 30-45 seconds. I have...
Could it be overheating, and automatically shutting-down, to avoid damage?
Shut it down.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed air, and give your computer a "blow-job", shooting compressed air into every orifice, to remove all the dust that could be acting like a layer of "insulation", preventing your computer from cooling itself.
Jan 04, 2010 | Dell Inspiron B120 B130 1300 / Latitude...
A Start with an Automatic Shut down?
Do you have check engine light on if so scan for fault code mean while sounds like coil pack this has a V-8 rite?
Dec 16, 2008 | 1995 Jeep Cherokee
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspire™ T180 PC Desktop
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Computers & Internet Logo
152 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
