Question about LG M227WD-PZ LCD TV
I have a sky splitter going into the back of my LG tv but I cannot tune it to receive the signal. Helo..
    Problem Solver:
  • 6 Answers
Try to tune with a direct TV antena if it works the problem is with the sky spltter, if not the problem is with the tunned system of the LCD...
Posted on Mar 27, 2010
I hope so I have a Logik Msn 30009831 HAD SKY TV IN WORKED fine, no sky now but cant tune in comes up no signal
make sure your tv aerial plugged in back of tv and your tv is on the dtv setting before trying to retune it. the sky box is usually on the scart or hdmi setting. hope this helps
Oct 07, 2016 | LG 32LD550 32 in. LCD HDTV
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
I don't have an aerial, I have satellite. I hav gone through the tuning several times and called the help desk: no joy. I have connected: Scart Sky box-TV....HDMI sky box-TV
The sky box is the box you use to watch TV The flat panel is just the monitor to receive the picture from the sky box you cannot tune the TV to receive the sky EPG signal Use the HDMI input in the TV menu that the sky box is attached to
Feb 22, 2016 | Televison & Video
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
I have connecting TV link with coax cable from my sky box to my LG 50PH660V 50-inch Widescreen 1080p TV But I can not get the sky to come on my TV. as channel 68 is DTV and on my remote it says TV/RAD
If I understand your problem the Y splitter is a passive splitter which mean that the centre pins are connected via capacitors this will degrade the picture on one or both outlets, the Sky box should be connected via a scart or HDMI connection
Feb 03, 2015 | LG Televison & Video
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
I got an American model of LG. i can not tune it by auto nor manual can you please help
You can get a manual here: http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-32LG30.jsp . Click on the Support and then on the right hand side look for User's Manuals. Since the TV has a tuner for ATSC, NTSC, and Clear-QAM, the next question is what is your signal source? (analog, digital and unscrambled cable)
If you are using OTA, make sure that the input is set to Antenna. Use antennaweb.org or tvfool.com to check the direction to point your antenna and the appropriate antenna for your distance to the transmitter. antennaweb assumes an external antenna and is very conservative in the list of channels you should be able to receive. tvfool gives the stations available with different antennas. If you have several tvs connected to one source, you may need an amplifier in addition to the splitter. This also can help marginal signals come in since digital is either enough for the tuner to resolve or no signal. (Check splitters and amplifiers if you suddenly can't get a signal that you used to receive. Also check if the antenna has been turned.)
Menu > Channel > Auto Tuning or Manual Tuning. If Lock System is active, you will need the password. Auto Tuning only searches for digital or cable channels. The manual tuning option should provide the signal strength as well for digital stations (as well as letting you search for analog signals or all signals (digital, analog, cable).
Use the input Cable for coax cable connections. Other inputs will not allow you to search for channels since they are meant to be controlled by the set-top box feeding the system.
I hope this helps.
Nov 05, 2010 | LG 32LG30 32 in. LCD HDTV
I WANT TO BE ABLE TO SEND SKY TV SIGNAL TO ANY ROOM, i HAD THIS IN OUR LAST HOUSE BUT CAN NOT REMEMBER HOW i RUN ALL THE COAX CABLES. i HAVE AN APLIFIER IN LOFT WHICH CABLES TO EACH ROOM, SO DO i NEED TO...
put coax from sky box output then into splitter in loft ampifier and conect all other coax that run down to other rooms to the outputs in amplifrer and turn on sky and put menu on then tune tv's in on anolog station
Dec 20, 2009 | Panasonic TH-42PX60U Television
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Sky magic eye not working on hd
I work for Sky as an Engineer.
on your Sky HD remote:
service,
4,
0 1 select
make sure the power is turned ON
now go to the room you can not change the sky channels over with.
you should notice on the magic eye itself should now have a Red led light on it now. you should now be able to change the channel over just remember to press the blue sky button on the remote at the top otherwise this will not operate the sky box.
If not unplug this magic eye and try this directly into RF out 2 to make sure that its not the magic eye that is at fault. If it is working correctly then the light will appear.
Hope this helps
Little dish fitter
Aug 16, 2009 | Televison & Video
LG M227WD-PZ LCD TV Logo
157 people viewed this question
Computer Repairing
Computer Repairing
