Question about HP OfficeJet 6210 All-In-One InkJet Printer
Am looking for the plastic gear/driveshaft mounted under the top lefthand cover used for paper feeding from top tray.
Document won't feed
Paper Pick up Rollers get dirty or worn out with the passage of time. Hence, require cleaning or replacement if worn out. In case you find them dirty use a soft, dry, lint free cloth to clean the rollers. Dont use chemicals as they may damage the rubber and plastic. However, if needed, you can use damp cloth or some cleaning liquid such as mild detergent of glass cleaner to damp the cloth. As you have posted your question under Panasonic KX-FL511 is would highlight the steps for it. Im Using a similar model KX-FL612
After lifting the top cover, you have to pull down the under part of it down to locate the rollers
Lift the top Cover, Locate the roller and clean them..
Hope it helps! Good Luck!
CreativeTECH
Dec 01, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
I have a message on screen sayng " ADF Jam" there is no paper jamming the system. I cannot make this message go away, and so i cnnot use any other function of the printer. How might I clear...
Hi travlynn2,
  1. The ADF
    unit is the grey paper tray located on the top of the scanner unit.
    Check the following points if it does not feed paper, or you receive an "ADF jam" error message:
  2. Check the position of the ADF document guide:
    1. Lift up the ADF unit. Locate the document guide on the underside, as shown here:
    2. The document guide should be tucked in behind the grey plastic casing, but a paper jam can push it out of position. Figure 8 below shows the correct (1) and incorrect (2) positions:
    3. If your document guide looks like example (2)
      on the right, lift it out on the right-hand side. Tuck it in behind the
      grey section, so that it matches the example on the left (1).
    1. Close the scanner unit.
    2. If the printer is displaying "ADF Jam, press start to continue", press the B/W Start button to clear the error:
    3. Test the printer by scanning or faxing via the ADF unit.
  3. Check the ADF edge guides:
    1. The adjustable paper tray edge guides must be set to the correct paper size for the paper you are loading. Otherwise, the paper may skew, misfeed and/or jam.
    2. Slide the edge guides to enclose the loaded
      paper (in the direction of the yellow arrows below), without causing it
      to bunch or crease. The paper should be aligned with the relevant paper size marker:
      Figure 9. The ADF edge guides.
  4. Check the ADF unit feed rollers:
    1. Open the cover of the ADF by pulling up the grey lip, as shown below:
    2. Check thoroughly for fragments of paper and foreign objects. Take care not to tear any jammed paper when you remove it.
    3. Use the green gear (circled in yellow below) to turn the paper feed rollers and feed through jammed paper:
    4. Paper dust or foreign material on the rollers may cause paper to misfeed. Clean these parts with a damp, well-wrung cloth:
      1. The upper paper pickup rollers (circled in red, above top left). You can turn these by hand.
      2. The lower paper pickup rollers. These will rotate as you turn the green gear (circled in yellow above). See the inset for a close-up of the lower rollers.
    5. When complete, close all the covers.
    6. If the printer is displaying "ADF Jam, press start to continue", press the B/W Start button to clear the error:
    7. Test the printer by scanning or faxing via the ADF unit.
  5. Check that the ADF unit sensors are not obstructed.
    1. Open the cover of the ADF unit.
    2. Look at Figure 12 below. Check the position of the black plastic parts (the actuators) circled in red.
    3. If the black plastic actuators do not stick out from the ADF cover, they may have been pushed out of position by a paper misfeed and be obscuring the ADF sensors. Tap the back of the ADF unit firmly to release the actuators.
    4. When complete, close all the covers. Check and test the printer as explained in Step 6.d.vi.
Hope this helps.
Thank you for using FixYa.
Sep 21, 2011 | Epson ACULASER CX11NF All-In-One Printer
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Jan 27, 2011 | Ricoh Aficio 450 Copier
Will not feed paper. Can print with manual feed in center of printer, but will not pick up paper in tray. It tries three times and can hear the motors whirring, but then stops trying and the attention...
When you look into the tray with the flashlight, you say the top rollers are spinning, are they touching the paper?
Pull open the tray and while you look from the back with the light, close the tray and see if the paper is being lifted to meet that top roller. Take out all the paper and watch it again. Make sure that the platform that the paper sits on in the tray is free to move up. Sounds like it is jammed.
Also check that roller that isn't spinning. Try to GENTLY rotate it with your fingers. If it does rotate, replace the tray. If the paper in the tray doesn't lift, replace the tray.
Oct 30, 2010 | HP LaserJet 1320 Printer
PAPER LIGHT FLASHING RED BUT MACHINE HAS PAPER IN IT
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 07, 2010 | Brother HL-2040 Laser Printer
How do I fix a paper jam on a HP2430 printer. The paper is jammed infront of the Drum of the cartridge. Looks like the drum is not spinning with the gear. What could it be? Theo
Theo, remove the drum and paper tray.
Disconnect the power source.
Carefully reach under paper tray and tray to pull paper out.
Sometimes depending upon the unit, you may find a flap inside the drum area, that lifts up.
If you cannot remove the paper jamming unit, you may want to find a plastic folder, which you will need to cut the same size as the paper you are using.
Feed this in buy hand trying to free up the lodged paper.
Most of the time, its a small piece stuck in the left corner.
Good luck.
Nov 24, 2009 | HP LaserJet 2430 Printer
Brother MFC-8840d ADF feed problem
Hi, the left hinge is spring loaded to keep the lid open. This applies a lot of pressure on the pivot point of the hinge (steel pin/plastic hinge) that elongates the plastic holes and raises the lid from the scanner. As the paper leaves the scan window, a ramp next to the scan window sends the paper up to the tray, just past that ramp under the lid is a lip that guides the paper to the tray. With the hinge stretched, the lip is too high and catches the end of the paper at the rear only, and jams the paper. If you press on the cover (with the new hinge) and it does not catch then you have installed a bad hinge. Also ensure that the top part of the hinge is on the guide pins under the cover.
Jul 29, 2009 | Brother MFC-8840D All-In-One Laser Printer
HP 2840 Jam in Print Paper Path
There are 2 primary paper sensors. One is the registration sensor where the paper feeds in, the second is associated with the fuser unit.
The first sensor is located under a cover under the transfer unit.
i) Open the door
ii) Lift out the transfer unit (Q3964A)
iii) Locate the black plastic cover plate with a small green flap in the centre. This assembly is directly under where the transfer unit was installed.
iv) There are 2 shiny screws that secure this cover plate. Carefully remove these screws.
v) Lift out the black cover plate by lifting the left section up first which allows the right section to come clear of gears.
vi) Check for paper obstructing the small movable lever under the cover plate.
vii) To reinstall the cover plate, insert the right hand side down first and line up with the mounting holes.
I can supply photos if required.
Jan 10, 2009 | Ricoh Aficio 250 Copier
Sharp F0-5700 Fax No Paper (Tray)
Remove the tray out of the copier and look for one next to the feed tires.
Jan 08, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Paper feed
Feed roller is dirty or worn thin, wipe rubber roller with damp cloth.
Nov 03, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
HP OfficeJet 6210 All-In-One InkJet Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
