Question about AT&T E2600B Cordless Phone
"Play Messages" missing
The "Play Messages" option on my AT&T E2600B has disappeared from the menu display on my base. My only options available now are "Calls Log", "Base Settings", and "Display Base ID". How do I restore the missing option(s)?
3 Suggested Answers
SOURCE: handsets won't hold charge and have no base subscription
smash it into little pieces! That's what I'm doing with mine.
Posted on May 31, 2008
  • 105 Answers
SOURCE: Lost handbook for my AT&T
go to the site below and download....
if link doesn't work go to and enter your product info in dropdowns.
Posted on Dec 03, 2008
SOURCE: Cordless phones display searching for base.
Same problem: registering base ID on cordless get T23 PD error and subsequently, Searching for Base
Posted on Sep 29, 2009
0 characters
1 Points
I do not have the code to remotely call my machine
You would probably have to go into an options menu and set a code yourself, Not sure of the steps on your particular model, but that's how every one I've ever owned worked.
Apr 23, 2014 | AT&T E2600B Cordless Phone
Why my uniden dect 6.0 answering phone has announce only and not record message
Check settings. Go to menu / sel button, press once. Scroll down to answering setup. Select. Scroll to record time. Options are announce only, 1 min. Or 4 min. Make selection. You will know your machine is ready to answer and record messages by the change in the LCD display on phone base from "A" (announce only) to a number, designating the number of messages previously saved.
May 11, 2012 | Uniden DECT 6.0 Cordless Telephone...
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
Dec 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Dont know how to set voicemail and directory
1.Press the "Menu/Select" button.
2.Use the up or down arrows to navigate to the "Voicemail Setup" option and press "Menu/Select."
3 .Navigate to the "Access Number" option and press "Menu/Select."
4 .Use the number pad to enter your voice mail access telephone number provided by your telephone company. Use the "Mute/Remove" button to delete any numbers entered by mistake.
5.Press "Menu/Select" to hear the confirmation code.
6 .Program the "Password," "Play," "Erase," and "Skip" options following the above steps, substituting the "Access Number" option in step three with the option you desire to program.
7 .Dial your voice mail by using the "Voicemail" button on the telephone.
8 .Listen and follow the prompts provided by your telephone company to set up your voice mail's greeting.
9 .Use the "Voicemail" button any time you wish to dial into the system to listen to voice mail. Use the programmed "Play," "Skip," and "Erase" options to navigate through your messages.
Apr 15, 2011 | Vtech Phones
Cannot figure out to set answering machine on my vtech, I recevied as gift.
Turn on the answering machine by pressing the on/off button on the base. Set the time and date by pressing the Time/Set button (to the right of the menu button) and pressing Change until the correct day or time is heard. Then press Time/Set again.
To record a message, press Menu until you hear "Set Outgoing Message", then press Record and speak the message (include the mailbox info if you are using them). Press any Play/Stop button to end the message.
Set the various features by pressing Menu to access each one, then press Change to change the setting. Press Time/Set to lock in the change and press Menu to change the next feature. Press a Play/Stop key to leave the menu.
The most important one is "Set Announce Only" to Off for callers to leave a message.
All messages will go into Mailbox 1 unless the caller indicates a different mailbox. Press the Mailbox button to hear new messages if the mailbox has a mix of new and old messages. Press the button a second time to hear all messages. Skip/Quick lets you advance to the next message and Repeat/Slow will let you hear a message again.
Press Vol (up) to adjust the base speaker volume higher during playback.
In the menu, the first option lets you set the two digit security code to access the messages when you call in from another phone. When calling press # followed by 1, 2, or 3 to access the desired mailbox. Press #4 to repeat a message. #5 to skip. Press *0 to end the remote call.
For the full manual, see: and scroll down to 5866.
I hope this helps.
(all this assumes the base is on (connected to power) and connected to a good phone line. Without power it will not work at all. I test phone lines for dial tone with an old corded phone.)
Sep 25, 2010 | Vtech i5866 Cordless Phone
I need to hear and delete messages on my uniden
The Uniden DECT6.0 come in various shapes and forms (many models). On the base you should have a button that says Play (or the picture of a play button with the arrows pointing right). Pressing that button will allow you to hear the messages.
Also, you must have a button that says ERASE or shows a slashed 0. Press the button to erase the messages. You may hear a message telling you to press the button again to erase ALL messages.
Alternatively, you can play them from the handset. You might have a Play/Arrow button which you press to play messages. When you finish playing messages, you hear the phone reading a few menu options to erase, save etc.
Jan 28, 2010 | Uniden DECT 6.0 Cordless Phone ID
How do i retreive my voicemail on my vtech 5.8 phone?
Hello, Below are the instructions for voicemail retrieval for your Vtech CS5121-2 5.8 GHz Twin 1-Line Cordless Phone. I have included an easily clickable and printable PDF link of the user's manual for this phone from the official vtech web site. I hope this helps you!
- CBR2009
New message indication The message display counter will flash when there are new answering system messages. If the new message alert tone is turned on, the telephone base will beep every ten seconds when there are unreviewed messages. Message playback Press /PLAY/STOP to listen to messages. Press /PLAY/STOP again to stop playback. If you have new messages waiting, you will hear only new messages (oldest first). If there are no new messages, the system will play back all messages (oldest first). When playback begins, the total number of messages is announced, followed by the day and time of the first message to be played. Options during playback Press VOL+/VOL to adjust the speaker volume. Press >>/SKIP to skip to the next message. Press<</REPEAT to repeat the message currently playing. Press <</REPEAT twice to listen to the previous message. Press X/DELETE to delete the current message. The system will advance to the next message. Click below for PDF USER'S MANUAL
Aug 18, 2009 | Vtech CS5121-2 Cordless Phone
E17 and V141
I had the same problem after I moved to my new home.... The main E2600 base/machine/phone worked fine, but the satellite phone did not. It just kept flashing E-17.
I took the batteries out for a few seconds and reinstalled, and when I put the phone back on the satellite base, it found the main base and worked fine.
Hope this helps.
Dec 31, 2008 | AT&T E2600B Cordless Phone
It largely depends on what model of switch the phones are connected to, however here are some links to user card and voicemail instructions, hope it helps.
To listen to your messages:
A number of options are available to you during and after listening to a message.
The table “Listening to your mailbox messages” shows the options and when they
are available.
1. Press ƒ·°⁄ to open your mailbox.
2. Enter your mailbox password and press OK or £.
3. Press PLAY to listen to your messages. For options,
refer to the table "Listening to your mailbox
4. Press ® to end the session.
Option Button Available
listening to a
listening to
a message
Backup ⁄
X Rewinds the message nine seconds and
resumes playing it from that point.
Copy fi
X X Sends a copy of the message to one or more
mailboxes. When you record the introduction
to the forwarded message, the introduction
must be more than three seconds long.
End of
X Skips to the end of the message.
Envelope † X X Plays the information on the message envelope.
Envelope information includes the date and
time the message was sent and, if the message
was internal, the directory name of the sender.
This option is not shown on the display.
Erase °
X X Deletes the message currently being played or,
if no messages are playing, deletes the
message just played. Deleted messages remain
in your mailbox until the session is ended.
(Refer to Notes 1. and 2.)
Forward ‹
X Advances the message nine seconds and
continues playing from that point. A message
can be forwarded as many times as required.
Feb 01, 2008 | NorStar T7316E Corded Phone
AT&T E2600B Cordless Phone Logo
13 people viewed this question
Top AT&T Phones Experts
Are you an AT&T Phone Expert? Answer questions, earn points and help others
