Question about GE Washing Machines
How do you open GE washer model WJRE5550H1WW? When my washer adds water, some of the water drips down towards the bottom of the machine.
On the front panel under the lid/top piece are two clips use a screw driver to push trawards machine and it will bring front panel towards you and unhinge piece wala! all exposed
Posted on Jun 23, 2010
How to replace seal of ge top load washer
You have asked a number of questions. How old is the Washer?
Based on your questions, it may be time to replace. No I am not a
GE Rep. Parts can be ordered online. Google Appliance parts. They may be able to help with "how to's". If newer machine, still warranty? If so check with GE. Otherwise, if the tub isn't being over filled and spin out doesn't send water outside the outer tub which could explain the dripping. Verify gasket leak by leaving water in tub and measure height of water very carefully let stand several days and remeasure.
Remove top should be springs on the front. Push in, to release, tip-up top. Tub must be removed. Remove the agitator by removing the top plastic, should reveal top nut holding down the agitator. You will see a number of nuts holding the agitator tower to reveal gasket. There may be rusting and pin holes causing the leak. I would check this before attempting gasket. I had a similar issue, used JB Weld epoxy about 5 year ago, still not leaking. Possibly the agitator tower has a seal leaking at top. If so that is in transmission and should be replaced as well as the bottom gasket. It may be $200 part.
Due to all the trouble, I replaced it to prevent future failure. You may find a lightly used replacement washer for about that price.
Nov 18, 2014 | GE Washing Machines
I have a model WJRE5550H1WW washer that will fill agitate but will not pump out and spin
first check the lid switch, a lot of washers will agitate with the lid open but wont spin out. If its not that check your timer and then your water pump. Most likey it is the lid switch.
Feb 27, 2012 | GE WBSR3140DW Top Load Washer
I have a GE stackable unit and I recently broke the belt on the washer- I think. Can I fix it? How do I get the unit open? Thank you for any assistance you can give.
Two screws on the very bottom, remove them and take something flat and insert it in the crack where the washer top is and the front panel. The front panel will slide down and out towards you...if no water is in the unit then push the tub back towards the rear and the motor will lift enough to work on it, replace the belt around the main pulley and then push the spring loaded pulley towds the left towards the main pulley and slide the belt onto the motor pulley...
Apr 10, 2011 | GE Spacemaker Washer and Dryer Electric...
I have a GE Top Poad WasherWJRE5550H1WW that intermittantly leaks
There seems to be an overflow drain from the top of the tub to the bottom (inside the cabinet). I don't know why this was designed to dump water onto your floor.
May 13, 2010 | GE Washing Machines
Model blown on washer
1 year parts and labor.But some is up to 10 years. Here is a link to look at you warranty.Here is G.E phone number.1-800-432-2737 http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90351.pdf
Jan 15, 2009 | GE Washing Machines
Our dishwasher was gushing water after a cycle
If you dish washer pumped or drained water up into you sink then you drain line from the sink or even further down is clugged up, Machine out drain line. A drip sized cable machine can be rented. I recomend a 1/4 inch line. You will only have to go frim the sink to the main line.
Dec 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
Oct 09, 2008 | GE WBSE2090A Top Load Washer
GE Top-loader Leaks Water from Vertical Tube Behind Tub on X-Large Loads
it sounds like the basket is not locked when it is agitating, if so the water will climb the wall during the wash cycle and leak out of the overflow (which is the plastic tube you described). if this is the case, it is a transmission brake problem. it can be fixed by a professional, but you might want to look into buying a new machine.
Jun 18, 2008 | GE WHRE5260E Top Load Washer
NEW WASHER WILL NOT SPIN OUT ALL WATER. DRAIN IS NOT KINKED AND IS AT 48 INCHES OFF FLOOR. MODEL IS WJRE5550H1WW WE HAVE IT ON EXTRA SPIN AND WE MATCH LOAD; MED SIZE LOAD / MED ON COTTON SETTING
I have the same problem, I called GE and they said there is definitely something wrong with the machine if I can just wring a bunch of water from the clothes and suggested to put a service call, seeing as I bought it last week I am going to see if I can get lowes to replace it with a WJRE5500GWW instead.
Jun 02, 2008 | Washing Machines
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Washing Machines Logo
451 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
