Question about Sanyo PLC XU35 Multimedia Projector
I need to replace the VGA cable on my Sanyo projector, model PLC-XW55. I don't know what to get. It's a male-male cable .
  • Anonymous Mar 29, 2014
    how to make cable
    is the male end the same as the female end
  • 292 Answers
Hi hotpinkvalen
If you have a VGA cable, take it to a computer shop or **** Smith and buy a new one.
Just tell them you want a VGA cable. It costs $6 to $10 depending on the shop.
If you don't have one, and if you don't know how it looks like, goto any desktop computer and have a look at the cable which is connected from the computer to the monitor.
It is a male-male cable both ends of the cable have 15 pins.
Hope this will help you
Best of luck
luciana44
http://www.sanyo.com.au/support/instruction-manuals/plc-xw55-instruction-manual
Posted on Oct 02, 2009
Connecting sanyo pro xtrax multiverse projector to a Macbook pro
VGA to HDMI cables don't work. They're a con. VGA is an analogue signal. HDMI is digital. It's not possible to convert from one to the other with just a bit of wire.
Sep 02, 2014 | Sanyo PLC-XU101 Projector
My sanyo projector model no plc-xu84 not working on som lap top computer
check the vga connections or toggle the fn+ what ever f key on that make of laptop.
check the projector is set on computer mode
Feb 09, 2011 | Sanyo PLC-XU84 Projector
Warning light on projector. The projector turns off.
Has it overheated?
Has the lamp expired?
Has a fan stopped working?
Has the ballast unit failed?
Which lamp is flashing?
More details please if it is not one of those common problems.
Thank you
Jan 03, 2011 | Sanyo PLC-XW55 LCD Projector
How do I get free service manual for Sanyo PLC-XW55
SE QUEMO LA ENTRADA DE VGA Y NECITO PLANOS PARA COLOCAR VALORES EXATOS DE RESISTENCIAS E INTEGRADOS
Nov 18, 2010 | Sanyo PLC-XW55 LCD Projector
I've connected the projector to my laptop using the VGA cable as stated in the manual. The projector reflects as it should, i can access the menu and input options which i then select RGB scart (though...
Not with any RGB input options, computers are not compatible with these. The projector needs to be set up to receive VGA. There must be a toggle button or menu entry somewhere on your projector that lets you do this or why would it have a VGA input?
Dec 07, 2009 | Sanyo PLC-XW55 LCD Projector
Connecting my pc to a sanyo plc sw30 projector
never mind the usb, u need to only connect the video output ( yellow rcs connector ) to the vido input of the projector & it will work fine!!!
Dec 29, 2008 | Sanyo PLC-SW30 Multimedia Projector
Sanyo Pro Xtrax Projector
not all computers are F4 - some are F7... - If there is not a small graphic on each Function button - just press and hold your function button and I'd start with F3 then F4 then F5 and so on - often your image will appear on the projection screen and disappear from your laptop - just re press Function and the appropriate key - you may also need to change your display - go to your control panel then display then settings and you will want 1024x768 - as far as cables you will need a male VGA that will plug into (usually blue) connection on your laptop and then depends on what type of projector you are using - it may take a VGA or RGB (5pin cable ~ red green blue horizontal vertical) make sure that in your menu settings that you have it set to the same as the input you have plugged into
Jan 19, 2008 | Sanyo PLC XU35 Multimedia Projector
PLC-XW55 KEY LOCK FEATURE
Hi
If you accidentally lock the projector, you need to disconnect the AC power cord. Then HOLD the SELECT button at the same time as reconnecting the AC power cord again.
This should reset the lock out.
Dec 24, 2007 | Sanyo PLC-XU47 Multimedia Projector
Sanyo PLC XU35 Multimedia Projector Logo
235 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
