Question about HTC G1 Smartphone
I forgot the key lock code for my g 1 and want to
I forgot the key lock code for my g 1 and want to start using again
I forgot the number lock code on my LG 4G lte vs840 how do i reset it
I believe your talking about the Lucid VS840. If so, you can try two things. 1. You should be able to use your grandsons google act username and password to unlock. Or 2. Do a factory reset. And this is how. Turn off the phone > Hold and Press Power keys + Volume down key at the same time for about 12 seconds > Release keys at "Permanently Erase User Data & Reset Settings?" > Press Power key to comfirm > Press Power key again, then just wait till the reset / master / hard reset finish it process. Hope this helps :)
Feb 01, 2013 | Motorola Cell Phones
Tolong brapa kode nya teman..?
*7370# and enter the security code, It will format your set and all code? But if your forgot the secuirty code then you have to download some software for the purpose.
Regards,*#06# for checking the IMEI (International Mobile Equipment Identity) for Nokia 7610 To view Week and Year of manufacture enter *#3283# [*# D A T E #]
The last two digits are the year. If the year is 95, the first two digits are the month. For 96 the first two digits are the week of the year.
To view the software version on Nokia 7610 enter *#170602112302# or *#9999#
On newer phones, the code has been changed to *#682371158412125#
All Nokia phones (Nokia 7610 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1)
The main code used in Nokia 7610 phones is :
#pw+(master code)+Y#
This code is able to check, activate or remove Sim card restriction (SP-lock).
Use the * key to get the p, + and w chars.
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
(master code) is a 10 digit code, based on the phones IMEI number.
Eg. To remove restriction on lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
Bypass the SP lock With a Nokia 16xx/21xx/31xx/51xx/81xx
1. Insert SIM card of different provider.
2. Turn on the phone and press the UP VOLUME key for 3 sec.
Then release it and the phone says PIN CODE?
3. Press the "C" key.
4. Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
Dec 12, 2011 | Nokia 7610
I forget my unlock security code nokia 1280
i forgot my nokia 1280 security code how to unlock it
Jan 29, 2011 | Nokia 1280 Cell Phone
Orgot my security code Nokia 1100
IMEI: 359399009958078Mastercode: 6260611472
Use this calced 10 digits mastercode at the same points where the phone normally asks U for the security code.
Apr 06, 2009 | Nokia 1100
Forgot my lock code
Dear my keypad light is not working please tell me how can i fix this problem
Regards
Ali
Aug 17, 2008 | Nokia 6630 Cellular Phone
Hi i have photo copier minolta dialta di183
Enter the admin mode (U-5) by holding down the Panel Reset key for 3 seconds (until "U- " appears in the display), entering the number 5 from the keypad, and pressing the start key. Enter the 6 digit administrator code and press the start key again. The display should show "Ad-". Enter 1 from the keypad and again press the start key. The display should read "0". Hit the clear key, enter "1" and hit the start key yet again. Hit Panel Reset several times (or turn the machine off and back on) to return to normal operation.
The default administrator code is 000000.
If you do not know the administrator code, it will be necessary to reset it using the tech rep mode. Enter the tech rep mode by pressing the Meter Count key and hitting "Stop - 0 - 0 - Stop - 0 - 1" quickly. Then hit 7 and the start key. The administrator code will flash. You can write it down and use it, or hit the clear key and enter a new code, then the start key. Exit as above.
Jul 03, 2008 | Minolta DiALTA Di183 Copier
Security code tel me
1) If you have locked the SIM, and forgot the password, after trying it wrong for 5 times, it will ask for PAK-1 or PAK-2 code.
These codes are generally written in the packet that comes with the SIM-CARD.
If you can not find the PAK-1/2 for SIM Card, please contact Hepdesk over phone and they will provide you.
Again, if you enter PAK-1/2 key wrong three times, your SIM will be blocked and you have to take a new SIM-CARD (you will get the same number) for which your service provider may charge you 2$ to 4$.
2) If you have blocked your Handset with Security code, and forgot the password, take it to service center and it can be easily flashed by them.
May 19, 2008 | Computers & Internet
Forgot Keyboard Lock Code
Three worked for me agagined a new number to phone it was the last four of the phone number
Oct 19, 2007 | LG enV VX9900 Cellular Phone
HTC G1 Smartphone Logo
85 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
