Question about Westinghouse L2046NV Monitor
LCD Monitor. I get a power light that goes to green then a quick very light flash of light on the screen, then the screen goes completely dark. I can not see the image with a flashlight as other posters have mentioned. Steady green light stays on. I've pulled the back of the machine and all of the caps look okay. They don't look blown at all, however the metal cover that covers the components is all black in spots, like something burned or significantly overheated. I am willing to replace components, however the list on fixya that I found does not link up to the supplier properly (mouser returns "bad request" when I do the links on some of the listed parts). So, in addition to information, I'm looking for a parts list if I need to replace parts. The parts list should be specific enough so that I can find it at an electronics parts store or online. Your help is appreciated. Thank you. Ron
  • Ron Fredey Oct 03, 2009
    Thanks for the list. I'll try that and see what happens.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the capacitors look fine then check for the power out put from the power board to other boards and to the back light inverter. I'll also suggest you to check whether the top of the caps are bulged or not & the resistors connected with the caps are also fine. You'll need a multi meter to check all of these.
Make sure that the cooling fans inside the monitor are working. If there is not enough power output from the power supply board you'll need to replace it.
Part # for Westinghouse Monitor L2046NV Power Supply- DAC-19M005
Also check these components--
Transistors--Q206, [Q205]
Capacitors---C204, CE101, [CE109],[CE103], [CE104]
SMT (backside of PCB, 4A 1210 SMT Fuse):F200
You can order these parts from---
2x On Semi 60V 45A TO-220 N-Channel FET
863-NTP45N06LG
2x Aavid Thermalloy Heatsink for above FETs
532-7139DG
3x Nichicon 220uF 35V Capacitors
647-UHE1V221MPD
2x Nichicon 1000uF 25V Capacitors
647-UVZ1E102MPD
1x Bourns 4A 1210 SMT Fuse
652-SF-1206F400-2
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 01, 2009
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
I have a Dell Ultrasharp 1907FPV, it's a few years old. Whenever I start my computer, the moniter stays dark and the green power button does these quick flickers. Eash flicker cycle takes less then a...
You don't have a short-circuit. That would have blown the protections or even the monitor. Refer to the manual, that flashing light may be a code that tells you the problem. I don't think the repair would be expensive...
Nov 29, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
Monitor L17AMTN flashes WinXP desktop, then blanks.
dmellman, Before you open it up, try this! With fully booted pc and WIN DESKTOP screen up, reconnect the L17AMTN . Have a bright flashlight handy so that when the lcd screen flashes on for 1 second and then goes dark, you will want to check to see if the desktop remains on the screen even though you think it went away. Shine the light 1-2 inches from screen at different angles. Has the desk top completely disappeared or is it still being displayed? Do you know about Cold-Cathode-Fluorescent tubes and their Inverter type power supply? I assume that this unit also has a "lay on floor black box switch-mode-power-supply" that is supposed to supply raw 12v-14v dc to the monitor? This symptom is typical of lcd monitor power supply failure, and or inverter board failure. Not to mention the fact that the CCFT's could be a bit tired from use. YOUTUBE has some videos on taking apart lcd monitors. also do search on web for "bad caps on lcd boards" or "bad caps in lcd monitors". I should think that this Tatung might suffer from swollen cap-itis. get back to me with results of your investigation. Im louie12fix on fixya or lmistyrel@aol.com just nrth of Windy City
Apr 17, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Monitor goes to sleep and won't wake up
You can google search for an app called NOSLEEP.EXE
It was written by a Symantec employee to keep your screen active regardless of pic settings.
Install and run it. That will verify the issue is with of or monitor
Software is free
Apr 09, 2017 | Mag Innovision LT776s 17" LCD Monitor
Need power supply board for H21 LCD monitor
H-21 scan port Dark Screen, If you unplug the green light flashes 2 or 3 times ending any activity until completely unpluged and plugged in again. My other scan port works fine using 1st monitor cables. I've used both ports on the graphics card. It's definately the monitor power supply or other componant.
Any ideas?
Bill
Nov 12, 2008 | Scanport H21 21" LCD Display Monitor
Black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Aug 05, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Display lights up then quickly goes dark
It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. If you do see the ?Start? button then either your backlight tube is bad or more often the inverter board is bad. Let us know if you have any other questions and please don?t forget to rate this posting.
Jul 15, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
Power goes green then back to standby
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Dec 29, 2006 | Mag Innovision LT765b 17" Flat Panel LCD...
Westinghouse L2046NV Monitor Logo
209 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
