Question about Brother Sewing Machines
Top thread in needle is not picking up bobbin thread- model LS30
Needle is not picking up bobbin thread- model #LS30
  • Anonymous Mar 25, 2014
    How to thread the bobbin
Bought a new machine!
Posted on Oct 09, 2009
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
Top thread will not pick up bobbin thread on my model 7422
try a new needle--make sure it's the right needle for the fabric
being sewed.
try rethreading the machine top and bobbin --make sure to use
every thread guide
try a different bobbin
it's also possible that the machine could have a timing problem
and needs to be checked
here's a free manual if you need one just click on the link
http://www.singerco.com/uploads/download/f3eff19dd0b1966512ad6a6bd24e3d8a74926fca.pdf
Dec 06, 2012 | Singer 7422
When the needle descends it gets stuck as it enters the bobbin case area. It will only release if I move the bobbin. The thread from the needle gets knotted up and pulls the fabric down into the bobbin...
Could be a few things. Absolutely minutely check that the top thread is threaded properly. Otherwise, it could be: Old thread. incorrect thread for the material. wrong size or blunt needle. or incorrect tension on needle I had this problem and I was missing a part of threading even though I have been sewing for years. :)
Oct 08, 2017 | Brother LS30 Mechanical Sewing Machine
My wife has a model 9110 sewing machine. It has stop picking up the thread from the bobin. Can you help on this fix?
Put new needle in
Make sure you have a 3-5 inch thread tail on both top thread & bobbin
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of machine & slowly lower needle into bobbin area & see if it will pick up the bobbin thread that way
rethread the bobbin,,also check the bobbin area for lint or loose threads
if none of these suggestions work, then the machine could be out of time & would need to be repaired
Nov 13, 2010 | Euro-Pro Sewing Machines
The top thread won't catch the bobbin thread to pull it through. It almost seems like it doesn't go around to pick it up. Or is the bobbin thread supposed to pop up more for pick up? This is my Mom's...
check the needle to see if it's damaged
have a thread tail for the top thread & bobbin thread of 3-4 inches
try this & see if it helps you
make sure there's a 3-4 inch bobbin thread then, hold the top thread tail (3-4 inches) with your fingers away from the needle & then use the handwheel on the right side of the machine & lower the needle down into the bobbin area & see if it pick up the bobbin thread that way
make sure there's no lint or loose threads in bobbin area
Sep 24, 2010 | Sewing Machines
Needle will not pick up bobbin thread
Chances are you will need to retime it if you have checked everything else, if you email me with your make and model I can attach instructions
Mar 26, 2010 | Sewing Machines
Needle will not pick up thread from bobbin
If you have correctly inserted the bobbin, try mmoving the top thread by hand gently up and down into the bobbin area. I let my top needle pick up the bobbin thread this way before using the pedal. I pull a long strand of bobbin thread out before pushing the pedal too.
Sep 21, 2009 | Singer Sewing Machines
Top thread will not pick up the bobbin thread
Timing is off, is is possible that you broke a needle or sewed over a pin. timing needs to be re set by a professional.
Aug 22, 2009 | Necchi Sewing Machines
Sewing Machines Logo
102 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
