Question about Panasonic WhisperFit-Lite Low Profile Bathroom Fan with Lights FV-08VFL2
How do u remove the cover to change the bulbs on panasonic whisper-fit low-pro?
  • 5,660 Answers
The cover is gently pulled down.
It only comes down so far, as it's held up by springs.
There are four springs. Two on each side. To gain more clearance on one side to replace the bulb/s, you disconnect the end of two springs on one side.
After the bulb/s are changed out, reconnect the springs, ease the cover back into position.
Posted on Oct 01, 2009
I do not see how to get at the lightbulb in my Panasonic Whisper Fan/light. I can not see any way to open the cover where the light is. What is the procedure?
Hi, I searched the web for answer and finally got it from the installation manuel. You have to take the whole cover off, not just the cover for the light. Below is the website for the installation manuel. ftp://ftp.panasonic.com/pub/Panasonic/business/building-products/ventilation-systems/pdf/install/08VFL2-E.pdf
The answer is on P.13-14.
Aug 15, 2011 | Panasonic Fan FV-05VFL2 WhisperFit-Lite...
How do I change the dip lights?
Hi D,
The high beam and low are in the same bulb. Open the bonnet, look behind the head lamp unit and remove the dust cover. Disconnect the plug from the bulb and then you'll see a spring clip holding the bulb into position. Release that and remove the bulb. When fitting the new one remember its pre- focused and must fit in only one way....it will have off set fingers so make sure all three sit correctly. Don't touch the glass with your figures as the bulb will blow when its turned on. If you have touched it by mistake clean with spirits before fitting.
Regards Johngee10
Feb 08, 2011 | 2001 Suzuki Grand Vitara
Does the whole headlight hav to be replace or can you just replace the bulb
bulbs are replacable on any vehicle. They mount through the back side
Jan 24, 2010 | 2000 Acura TL
How to change front headlamp bulb? Low beam
  1. Open the hood.
  2. Remove Grille.
  3. Remove the 2 retainers on back of headlamp assembly and remove the headlamp from the sheet metal panel.
  4. Remove the access cover from the rear of the headlamp.
  5. Disconnect the electrical connector from the socket.
  6. Rotate the bulb and socket counter clockwise in order to remove the bulb and socket from the housing.
  7. Disconnect the electrical connector from the socket.
  8. Remove the bulb and socket from the headlamp.
Installation Procedure Important: • Replace a high beam bulb with another high beam bulb. The high beam bulb has a black socket. • Replace a low beam bulb with another low beam bulb. The low beam bulb has a gray tip and a grey socket.
Oct 14, 2009 | 2002 Chevrolet TrailBlazer
How to change the bulb on the front head light on my 2002 jaguar x-type
Dip beam (outer) headlight
Open the bonnet.
Slide open the two spring clips (A) and remove the cover (B).
Press the spring clip inwards and push towards the bulb
to release the bulb and then remove the bulb from the light
unit. Pull the connector from the bulb.
Fit a new bulb to the connector, type H1 for dipped beam.
Fit the bulb to the light unit, the bulb will only correctly fit in
one position. Engage the spring clips to retain the bulb and then
fit the cover and retain using the two spring clips.
Close the bonnet.
Note: High Intensity Discharge (HID) Xenon light units,
type D2S 35W, are not renewable, contact your Dealer if the headligh fails to operate
Oct 07, 2009 | 2002 Jaguar X-Type
Headlight repair on 2003 Mercedes Benz E320
how do you change left low beam bulb on 2003 mercedes e320
Mar 15, 2009 | 2003 Mercedes-Benz E-Class
Low beam bulb on 2003 X-type
Hi Rod
Open the hood, remove the plastic dome cover, and then the bulb connections, un clip the bulb retainer, extract the bulb, and check with the new one that its same.
No fingers on new bulb or it will pop when you switch on.
Fit new bulb and retaining clip, refit wires, test it, then fit plastic cover.
Good Luck !
This is what it looks like under hood !
A FixYa rating would be appreciated Thank you !
e3ac4f3.jpg John
Feb 08, 2009 | 2003 Jaguar X-Type
How do you get the headlight bulb out to change on the 2001
outer/inner bulb, remove top black plastic cover that runs the lenth of the front of the car behind lights, turn the circular cover covering bulb anti-clockwise and remove, you will see a spring clip, push this clip towards the bulb and downwards, this will release the bulb, fitting is the reverse and the bulb will only fit in one position. It is awkward and space is tight
Jan 01, 2009 | 2001 Jaguar S-Type
Remove end cover to access changing bulb and cleaning mechanism
Hi paintbox,
There's actually a light-bulb changer available from Pfaff (at least it used to be available). Your Pfaff dealer should be able to get one for you. Makes it a breeze to change lightbulbs.
However... if it is no longer available or your dealer can't get it, you can remove the side cover - raise the handle and look down inside the machine BEHIND the left side of the handle. You should be able to look down inside the machine and see the top of a screw and fit a screwdriver into the space to loosen the cover. Just make sure when you put the cover back on that you tighten the screw down tightly - don't want it falling off while you're sewing!
Hope this helps,
Kim
Apr 30, 2008 | PfaFF Quilt & Craft Pro 7530
Panasonic WhisperFit-Lite Low Profile Bathroom Fan with Lights FV-08VFL2 Logo
202 people viewed this question
Top Panasonic Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Panasonic Hardware and Accessory Expert? Answer questions, earn points and help others
