Question about Homelite Garden
How do i install string on homelite 26ss - Homelite Garden
  • 472 Answers
YPU MAY WANT TO TAKE THAT TO A SHOP ITS KIND TRICKEY
Posted on Oct 01, 2009
Need to find where air cleaner is ?
If your unit has one, it would be in front of the carburetor. Some Ryobis and Homelite trimmers do not have an air filter on them, just a screen inside the choke cover.
Sep 08, 2011 | Homelite Mighty Lite Lawn Trimmer
Does this machine use a an air filter? I have the Mighty Lite 26ss UT21044 model.
Some of these actually use a screen cover with NO filter medium. Ryobis and Homelites are infamous for this.
Sep 01, 2011 | Homelite Mighty Lite Lawn Trimmer
Homelite Might Lite 26ss starts up but wont run for more than 20 seconds when idling and floods out when you give it throttle. i checked the fuel filter even ran it without the filter does the same thing....
I think with the symptoms that you are having, that you need to 1. Remove the carburetor 2. Inspect/Replace fuel filter and fuel lines 3.Disassemble and Clean the carburetor 4. Possibly install a new gasket and diaphragm kit or a complete rebuild kit.
Jan 26, 2011 | Homelite Mighty Lite Lawn Trimmer
Have a Homelite mightylite 26ss String Trimmer. When i pull the trigger in the run position it cuts out and will shut off continuously. I checked the filter screen and it is clean(looks brand new). I've...
Let the engine warm at idle adequately before applying full throttle. With the engine warm, slowly bump the throttle and see if the response is good: if the engine wants to die again, let it continue warming at idle. If the problem persists, check that you are mixing your oil/gas mixture at the correct ratio: too much oil and you risk clogged the works.
Oct 07, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Unable to base the cord on my homelite 26ss weedeater
as soon as i pull on the cord it comes out of plase
Jul 17, 2010 | Homelite Mighty Lite Lawn Trimmer
How do I feed string into my Homelite Mighty Lite 26ss grass trimmer? I don't have a manual and I can't figure it out. Thank you!
cut a 6 ft piece and wind it (starting with the middle of the trim line) around the head with each head going opposite directions. When you get it wound up, you will have two pieces sticking out in opposite directions and they can be clipped into the small plastic slots on the edge of the string canister. THen press the ball on, and attach to the trimmer.. Just keep the string the grooves and you will be fine...
OHYEAH!!! dont worry if it keeps coming unwound or pops off the trimmer at first, it will happen until you develop the technique needed for a quick replacement
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Jun 03, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite 26ss weedwacker won't start, its getting spark and gas.
http://www.fixya.com/support/t2258508-homelite_mighty_lite_26ss_weedwacker
May 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
295 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
