The bset way to do this is to have a switch or router, and connect them by network and transfer all your needed files.
the only problem you might have is, file sharing, meaning if the files you want is readily shared, but there is a way to do that. First try to borrow a montor or LCD screen and connect to the broken-screened LAptop, and try to share the files to network.
One more easier way to fo this is to install a monitor on the broken-screend one, install a USB external hard drive on it and then copy all the files you want. After copying thet, install the USB Hard drive on your perfectly working laptop and copy the files. This procedure is more easier than what you have in mind, cheaper too, because you can always just borrow a USB Hard drive or flash drive. Even a small capacity flash drive would do, it just takes more times of plug and unplug because of the capacity issue.
Hope this helps and Thank You for using Fixya.
