Question about Singer 3116 Simple
Get everything threaded and when I go to sew it bunches all up on the bottom either bunches or the thread is all loose
  • 268 Answers
Here's some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs
If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps you.
Posted on Oct 02, 2009
I have this exact same problem right now, thats why I am on the computer, I am trying to sew some curtains for my wife after a couple of beers and the frigin thing keeps jaming or not catching thread even tho after several trys I even decided to follow manual exactly word for word.
My Solution: Grab another Cold beer from fridge, calmly place sewing machine and the mess around it back into box, throw the fuckin thing back into the cupboard, take curtains to seamstress tomorrow and pay for it to be done. for medicinal purposes only Proceed to drink beer, repeat first and last step again.
Posted on Oct 26, 2009
When I finish to sew the end of string does not lacks it self and when you pull the bottom of the string everything opens
If the upper thread is looping on the bottom of the fabric as you sew, the upper tension is too loose. It could be threaded incorrectly, the upper thread may not be seated in the tension disk properly (be sure to RAISE the presser foot BEFORE threading the upper thread), or the upper thread tension is set too loose.
If you have checked everything and it is still looping underneath, the bobbin tension may be too loose or the bobbincase needs replacement.
Sewing Machine Thread Bunching Up Here Why
Oh You Crafty Gal Sewing Lesson 10 How to Fix Tension on Your Sewing...
Understanding Thread Tension Threads
Dec 20, 2015 | Janome Sewing Machines
Tension adjustment for denim with denim thread
If it is bunching and looping underneath, it's because either the machine isn't threaded correct on top or your top tension is too loose. For heavier sewing, your top tension should be set at 7 or 8.
Jan 12, 2015 | Sewing Machines
Thread bunching up on the bottom
try changing the needle
rethread the machine top & bobbin
make sure the top thread has not come off the thread take up lever
clean under the needle plate & in the bobbin area for lint or loose
thread
Aug 23, 2012 | Sewing Machines
My bobbin thread is bunching up underneath. I have taken the bobbin out and the bobbin assembly out but it still is doing it.
Gayle,
In a sewing maching, for the thread not to bunch up, there are two thread tension tighteners. One each for the bottom and the top threads. The top thread tensioner is a nut that tightens or loosens the thread tension. The thread passes under this nut. While for the bottom thread it is two screws on the casing for the bobbin. These two screws hold a small strip of metal to the casing and the thread passes under this strip.
To be able to get proper tension on both the threads you have to strike a balance on both the top and the bottom threads. If the difference is not much then you can do with varying only one of them, usually the top one for ease of functioning.
Since you say that the thread is bunching uo on the bobbin side, ie, the bottom, means that the top thread is too tight and must be loosened. You cant do it in the first go. It may take you a few attempts to get it correct, so do not loose heart if it is taking time.
All the best.
Jan 27, 2011 | Kenmore 11101 Mechanical Sewing Machine
When attempting to sew the bottom of fabric "thread starts bunching up after about 3 stitches....Help....what is wrong
you might try checking your needle to see if it's bent-roll on flat surface to see if it roll correctly
or blunt or damaged
some sewing machines bunch up like that when the thread come off the thread take up lever
also check the top tension
check for lint or loose thread in the bobbin area
check to make sure the bobbin is wound correctly
Sep 25, 2010 | Necchi 4575 Mechanical Sewing Machine
Thread bunces up on the bottom causing machine to
I would start by looking for a problem with the bobbin tension. Do you have the bobbin threaded through the case correctly? Is the the bobbin tension set to loose? Another thing that can cause it to spool up on the bottom is if it sews a bunch of stitches all in the same spot or real close, do you have the presser foot tension to loose?
May 23, 2010 | Singer 2263 Mechanical Sewing Machine
The bottom thred is bunching up when sewing
Usually when the bottom thread is bunching or looping it means the top tension is too loose or the thread may not be in the take-up lever. If you're top tension is set between 4 and 5 and it's still bunching, there may be a piece of thread or lint caught between the tension disks.
Feb 24, 2010 | Sewing Machines
THREAD GET BUNCHED UP UNDERNEATH THE FABRIC, THE STICHES SEEM TO BE INCOMPLETE THE TOP LOOKS GOOD THAN I TURN IT OVER AND THE THEAD IS BUNCHED AND LONG LOOPS OF THREAD ARE LEFT. THANKS LOU
Hi Lou! This sounds like a tension problem--the tension on the top thread is too loose. Try using different color threads on the top and bobbin, then carefully rethread everything. Stitch a couple of inches and check the underside. If the top stitches look fine and the bottom ones are loose and loopy, and with the pressure foot down, tighten the tension. Move the knob or dial (whichever you have) just a little bit. Sew a couple of inches more, and recheck. Continue to sew and recheck, gradually tightening the tension, until you see little if any bobbin thread on the top or top thread on the underside of the fabric.
Let me know if this helps, ok?
Robbie
Jan 27, 2010 | Singer Sewing Machines
Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Dec 29, 2008 | Singer 3116 Simple
Singer 3116 Simple Logo
406 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
