Question about Freezers
Compresor is short cycling
Compressor is short cycling
    President:
  • Freezers Master
  • 1,922 Answers
Your low on freon
Posted on Oct 05, 2009
When the cooling cycle is finished, the refrigerator will not stop running.
because cooling cycle and compressor is not same thing ,cooling cycle fixed beside the compresor you can see that.
Mar 13, 2013 | True 72 cu. ft. / 2039 liter Commercial...
Short cycle in freeze mode
a short cycle usually means it is cutting out on high or low pressure.If its low pressure add gas.If its high pressure make sure condenser coils are clean.amp check compressor if its real low its low pressure if its real high either high pressure or bad cap or bad compressor windings.
Apr 18, 2012 | Freezers
Electrician was here yesterday and shut fuze temporarily. It's back on, but system is not cooling. where is the reset button? Model: MSB2354AR
Hi and welcome to FixYa. I am Kelly,
There is no reset button. There is a thermal overload on the compressor called a KliXon and that is what should be cycling about every 5 - 8 minutes if the compresor did not start.
When there is a temporary loss of power 10 minutes or less there is a good possibility that the internal coolant pressures are way to high for the compressor to start. Unplug the unit for 15 - 20 minutes and plug it back in FIRST. (longer is better) This will give the coolant system time to equalize so the compressor can start. If after trying the unplug / wait / re-pulg routine it still does ot start or cool just repsond here and I will gladly help you.
Thanks for choosing FixYa,
Kelly
Oct 22, 2010 | Maytag Freezers
Fridgeaire upright freezer is getting warmer and warmer.How do I
there is no way of cleaning the coils.there maybe a problem with the compressor.you should hear a fan running inside the freezer when it is in the cooling cycle and the compresor is running if you do not here the fan running this could cause a cooling issue and the evaporator could be building up with ice.
check the rear of the freezer to see if there is any ice build up.
Jan 18, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Compresor is not running - a yelow and right
your power contactor relay on the compressor body is defective
Oct 25, 2009 | Frigidaire 17.8 cu. ft. / 504 liter...
Freezer motor clicks on but then clicks right off again
Make sure the condenser coil is clean and the fan works (if not replace it) If those are ok probably the compresor relay is bad (no more than $30) and after you replaced the relay ,if still the compresor won't start the problem is the compressor itself.
Aug 27, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Does not cool and compressor relay keeps intermittently buzzing every 1 to 2 minutes. Condenser coils are cleaned and when you check across the overload protector pins there is no continuity.
When there's not continuity across the overload is because the compresor overheated , it could be the relay or the compressor that is burned out or stuck .I would let the compresor coold down for a few hours (unplugging the unit) and replace the relay (no more than $20) and if still having problems the compressor needs to be replaced.
Aug 23, 2009 | Amana Freezers
Frigidaire for Kenmore Freezer-Compressor won't start
Set the thermostat to the coldest and check if there's power to the compresor relay , if yes the relay or the compresor are bad (in this case replace the relay which is the cheaper first step ,but if the compresor still won't start probably is burned out) If there isn't power to the compresor put a jumper wire to the thermostat if the compresor runs replace the thermostat.
Jul 31, 2009 | Freezers
My freezer sounds like its on, but it wont freez. I took off the cover, and the coils look clean. The black thing, I think, is the compresor is realy worm. None of the copper coils are cold.I don't know if...
if the compressor is warm that is an indication to me that it is running or at least trying to run. if its running you should feel it vibrating as well as being warm. assuming the compressor is running and it's not cooling I would say you probably have a refrigerant leak and would come out cheaper to replace the unit. repalceing the compressor also is fairly expensive in exess of 300-400 dollars. Let me know if you have any other questions Peyton
Mar 07, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
