Question about Motorola Mobility ic902 Cellular Phone
Want to know if it can be unlocked and work on boost new 50 dollar plan, with boost new sim card??
I need to unlock my moto g boost mobile and I need the unlock codes please.
Boost Mobile Moto Gis CDMA only. CDMA phones don't take SIM cards, and the only unlock available is bootloader unlock via Motorola's website. If your country doesn't have CDMA carriers, don't buy the Boost Mobile, US Cellular, or Verizon Moto G, unless you plan on using it on Wi-Fi only
Apr 22, 2016 | Cell Phones
I am trying to use the sim card and my current payment plans with boost on my old at&t phone that i got unlocked, but i need to know how to make that work..
the sim card is still tied to the previous service provider
get a new sim card from your new service provider
keep the plastic card that the sim card is attached to as there is the PUK code that you will need to open the phone stamped on that plastic card
Dec 10, 2015 | Nokia Lumia 635 Windows Blue Boost Mobile
If I put my boost mobile sim in my new unlocked phone can i keep my service with boost and my number?
Your sim card is only "programmed" to work with your current phone and carrier. For example, if you took a windows program DVD and tried to install that windows program on Apple's OSX, it would not work. That sim card is like the DVD. The program for your phone's carrier (since Boost uses other carriers like Verizon, Sprint and AT&T) will not work and may ruin your phone or sim card. Happened to me, so I know.
Dec 20, 2014 | Televison & Video
I have unlocked my blackberry cell phone by purchasing an unlock code. i purchased a boost mobile phone and time and now i'd like to transfer my boost mobile phone number and all of the info. in the...
If you are trying to use your Blackberry 9700 Bold on Boost Mobile then it may not work, as the phone may not support the technology with which Boost Mobile runs on. You would only be able to use Blackberry 9700 Bold on GSM carriers once unlocked.
Unlock Blackberry Bold 9700
Jul 14, 2011 | RIM BlackBerry Bold 9700 Smartphone
I have a boost mobile I465 and i wanted to use with nextel but it asked it me for a special code
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security Code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (Security Code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock Security Code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
You can also try this WEB site :-
http://www.mobileunlockguide.com/mobile-phone/
The IMEI number is unique the each mobile phone.
The number is printed on the label under the battery.
You can also get the IMEI number by entering this on your phone
*#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits
Jan 30, 2010 | Motorola Mobility Clutch i465 Cell Phone
How can you use a blackberry nextel phone with your boost plan
You do not need to "unlock" that blackberry.  If you put your boost sim in it the phone calling and direct connect will work immediately.  Getting the txting and internet to work require you to install other service books.  Try this link http://www.howardforums.com/showthread.php?t=1530734  which explains how to remove the old books and add the correct service book to use mms and internet.
Dec 30, 2009 | Motorola Mobility Boost Mobile...
Boost Mobile SIMs and Motorola V3 Razr compatible or not??
will not work with boost mobile, (even if it is unlocked) you might be able to use it with boost mobile cdma, which uses sprint service. they no longer advertise this service, but still accept new users. give boost a call and ask them for the boost mobile cdma number
Sep 08, 2009 | Motorola Mobility RAZR V3
I have an unlocked LG Viewty (but still with Original T Mobile System on it) working with Fido. I didnt have any problems until the signal disappeared. The phone is working but there is no reception. I...
Try getting an antenna boost card they are compatible with all phones I believe there is one called cricket antenna boost they have them on ebay for like three dollars I havent tried one but its the only way that i know to boost your signal power
Sep 22, 2008 | Cell Phones
Boost i 835 g sms problem!
you need to add a plan with boost or nextel, i know its ridiculous it won't show you the name. If you have boost make sure customer service has the right model phone that you have and the proper sim card and make sure they enabled pay as you text messaging
Jan 06, 2008 | Nextel BOOST i835g i835 LTD. ED UNLOCKED...
Motorola Mobility ic902 Cellular Phone Logo
76 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
