By default, the Magellan RoadMate has the region setting for the lower 48 United States. When the receiver is turned on for the first time it may ask you to assign regions. Select the map region you want to use by tapping on the item from the list. If you are travelling in other regions you will need to change the map region by using the following steps. 1 From the Main Menu, tap on the right arrow to access the second page of the Main Menu. 2 Tap on User Options. 3 Tap on Region. 4 Tap on the map region desired. The Region option will display the map regions that are available for the Magellan RoadMate you are using.
Also if you want you can download the user manual from this website
My Magellan Roadmate 1212 is always stuck on the last location that it is guided to. When I enter in...
(More)
My Magellan Roadmate 1212 is always stuck on the last location that it is guided to. When I enter in a new destination the Magellan Roadmate takes no less than 20 minutes to come up with directions.
I believe it has gone flat and now when I turn it on only the reset screen appears no other key is...
(More)
I believe it has gone flat and now when I turn it on only the reset screen appears no other key is functional
Magellen 1212: when i enter a new destination, and after it routes it, it brings up a map of the...
(More)
Magellen 1212: when i enter a new destination, and after it routes it, it brings up a map of the address of my previous destination instead of my actual current location. then, when i drive, it won't give me any directions for 2-3 miles. is the unit defective?
My Magellan Roadmate 1212 is always stuck on the last location that it guided me to. So the next...
(More)
My Magellan Roadmate 1212 is always stuck on the last location that it guided me to. So the next time I want to use it, it thinks that it is still in that location. I have to cancel route a few times until it realizes where the unit is. Is there a solution for this or do I just have a broken GPS?
