Question about Zanussi Dryers
There's water in the dust collection compartment, any tips?
  • Zanussi Master
  • 3,361 Answers
Your exhaust vent is stopped up. Also check your blower wheel. It may be loose.
Posted on Oct 01, 2009
Why My Rroomba 560 collects the dirt and after 2 or 3 circles gives it back on the floor. What is wrong?
Sounds like it's picking up the dirt, running it around the brushes and dumping it back out after one full circuit. I would check to see if anything big is caught in the brushes and preventing dirt from going into the filter compartment. Do you need to empty out the filter compartment and shake out or change the dust filter? If the filter is too clogged, dust won't get pulled into this compartment because there's no air passing through the filter to draw air.
Jun 16, 2014 | iRobot Roomba 560 Robotic Vacuum
Water dripping from front bottum of freezer compartment -inside of frigerator
The reason for that water drip is from a blocked drain of the defrost,since that drain is blocked it is causing water to collect/drip from the freezer.I have written a tip about how to clear that drain,
http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Oct 27, 2011 | Refrigerators
My Riccar Upright leave lines of debris when I use it. Can you help?
Inspect the filter.Open the secondary filter on the base of the vacuum to ensure that dirt and debris have not collected on the filter, as this will limit motor performance. Remove the filter from the dust compartment and rinse with water to clean. Allow it to dry completely and return to the dust compartment.--------
Also check if dust bag is got over full and that is causing the problem.Open the dust compartment, take the old dust bag out of the bag holder and discard. Open the end of a new dust bag and attach to the dust bag holder. Close the dust compartment and tighten the dust cover.Also check properly that dust compartment is not got loose. Open cleaning attachment and check the hoses and nozzles on the frequently to ensure that they are free of dirt, obstruction or hair.Also inspect the brushes, if there is already dirt got stuck in the brushes and that is causing the problem.Clean the brushed.---------- This will help, to confirm where the problem is and to resolve the dirt /debris issue.----- Thanks.Helpmech.
Sep 06, 2011 | Vacuums
Dehumidifier is not working, no lights, no noise, all settings on the humidity control don't make any difference. I am assuming it is in the circit board or some relay. The unit was exposed to drywall...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 11, 2011 | Kitchen Ranges
Water collects and freezes on bottom of freezer compartment. Water is not connected to refrigerator.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 04, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dripping down from freezer compartment and collecting in the refridgerator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 07, 2010 | Kenmore 73182 / 73184 Top Freezer...
CANT SEEM TO ADJUST WATER TO FALL DIRECTLY ON BLADE...GOES TO EITHER SIDE OF BLADE AND MAKES FOR A DUSTY CUT, HAVE ADJUSTED THE NOZZLE AND CLEANED THE TIP BUT SAME RESULT, ARE THESE RIDGID SAWS DESIGNED...
tile dust collects in the cast iron housing that the tip screws into. A sewing needle will help after you remove the guard to clear the orifice from both directions and then flush until desired effect is achieved.
Mar 06, 2010 | Saws
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Dryers Logo
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
