Question about HP LaserJet 4250n Printer
WHERE'S THE FUSER ROLLER AND WHERE DO YOU PURCHASE FUSER OIL ON A HP LASER JET 4250 N PRINTER?
  • 3 Answers
The fuser assembly is part of the HP Maintenance Kit. The HP part number is Q5421A. Be sure to use the one for the 4250. The 4200 and 4250 are so very similar but the maintenance kits/fusers are differnet. The 4200 is less expensive but can not be used. It fits but causes other issues.
Posted on Dec 23, 2009
    Problem Solver:
  • 13 Answers
The 4250 uses an "assembly" that does not use fuser oil. The fuser is housed in the rear of the printer. It applies heat and pressure to the paper as it exits, melting the toner into the fibers of the paper. Some fusers are remanufactured. If done properly, with the proper amount of fuser sleeve grease, these fusers can last as long as the original equipment fuser.
If not properly trained, fusers should not be disassembled and rebuilt.
Posted on Oct 27, 2009
My hp laser jet 4001n has a paper jam and does not burn the tonner
please check fuser roller assembly.there is an problem with heater.
Jan 26, 2014 | HP LaserJet 4100N Parallel/Ethernet...
Hp printer 4250 is error 50.0
Fuser Error, Replace the Fuser (Part Number RM1-1082) In the rear behind the door very easy to do.
Dec 29, 2010 | HEWLETT-PACKARD Hewlett Packard 21A - HP...
Hp 4250 laser jet vertical streak ghost image
The problem you are having is caused by the fuser. The fuser is the part in the printer that heats up and basically melts ( fuses) the toner to the page. The fuser has a heat roller that is coated with teflon, your fuser coating has worn off in spots so the toner is sticking to the roller and causing the ghost image. You will need to order a replacement fuser. You can do a search on Google to find a replacement, the parts number is RM1-1082.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 04, 2010 | HP LaserJet 4250 Printer
Need installation program
you can check how to setup, install and configure your HP laser jet 4250 printer from here
Click to see check the page
and here is the driver link for your HP laser jet 4250 select your operating system then download
Click here to Download the driver
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
Jan 12, 2010 | HP LaserJet 4250 Printer
I have HP Laser Jet 1020 When I print letters
Most cases on that machine it's the transfer roller that does that at 75mm, but could also be drum cartridge or fuser. Use a flashlight and inspect the fuser, shouldn't be toner or image on fuser rollers, If you unplug the machine when the print is in the middle, you can tell if it's before or after the fuser, and after the drum.
Nov 24, 2009 | HP LaserJet 1020 Printer
How do I clean the rollers on my laser jet printer, it prints with a long black strip in the middle of the page. Hp laser jet 1320
Most likely the heat roller is breaking down in the fuser. The fuser must be replaced. But before going that far, replace the toner cartridge, as it may have a bad cleaning blade. 85% of all print quality defects are cartridge related. This particular model of machine has a very brittle heat roller that more often than not wears out prematurely. This is true across the board for all of the newer HP low end laser printers unfortunately.
Sep 30, 2009 | HP LaserJet 1320 Printer
I have streaks on my print outs from hp laser jet
check your toner cartridge, check your fuser rollers and check your transfer roller assembly.
Sep 23, 2009 | HP LaserJet 4 plus Printer
Color Laser Jet 3800 leaving roller marks on paper
Pull out the fuser at the rear of the machine.
Feb 07, 2009 | HP Color LaserJet 3500 Printer
Fuser Error 50.1 Fuser is hot. What is a fuser?
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Aug 17, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 4250n Printer Logo
344 people viewed this question
Seeker5211
Seeker5211
