Question about Pentax Optio 550 Digital Camera
The camera will turn on, but shortly after shut off. what's wrong with it?
My Nikon s4300 won't shut off
1) You cannot control (Turn on/off) the camera while it's charging.
2) Check the mode the camera is in Some mode may keep the camera busy.
This is all I can add you your short problem description
Oct 01, 2017 | Nikon Cameras
Why doesn't it recognize the correct battery?
hi,
If your camera do not recognize the original battery, it means some wrong information is stored in its software data, to override this please open the camera take out the small memory backup lithium battery, short the battery contact , after a five minutes connect that battery again.
Mar 02, 2016 | Sony Video Cameras
My camera won't work I turn it on but it's telling me the batteries are dead but there brand new batteries then it shuts off!! What is wrong with it I got it for Christmas last year but up until like
is there a dc power adapter plug on it or use USB cord ito the PC.This way should able to check all settings & power saver timers.Not saying it is the reason but a friend had issues as camera drained batteries.A short may be the cause in the battery compartment or the sensor reading the battery power levels.My guess is manufacture flaw.But only solution I can think of other than a repair is leave batteries out.I had a Fuji Camera & will never own another.Have you tried YouTube search on solution? Good luck
Oct 16, 2012 | Cameras
Kodak camera when turned on, puts a blank white screen then turns off.
Condensation shorted out the circuits causing it to shut down. Put the camera in a dry place.
Dec 15, 2010 | Kodak EasyShare C613 Digital Camera
Batteries die quickly possibly a short
The battery is probably just bad. There is enough energy in these batterys that if there is a short you will definitely see it spark or smoke or even catch fire.
If you use the batterys till they are drained before charging, or if they are a few years old then the batteries are not going to be able to hold that much of a charge anymore. The camera might only start then shut off or take one or two pictures and be dead. That is typical of old batteries needing replacement. If you charge your batteries then take them and the camera to a camera shop and ask if they would check. they should be able ot put a battery into the camera or try your batteries in another camera so you can see what is wrong.
Nov 13, 2010 | Canon PowerShot SD800 IS / IXUS 850 IS...
Was taking pictures and the camera shut down, put in new batteries and nothing happened
It could be that you have the auto power off set to a short time like a minute
Apr 16, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Shut down
You may have damaged the memory card not the camera. Try the card in a card reader and also a different card in the camera.
Good luck
Apr 14, 2008 | Canon DC20 DVD Camcorder
Camera beeps 3 times the shuts off
I've decided to send the camera in for possible repair.
Feb 17, 2008 | Samsung S630 Digital Camera
CAMERA WON'T TAKE PICTURES?
i don't know what age the camera is, did you try full batteries , normally it shouldn't do this it must have a defect if the batteries are not the problem..
perhaps contact the dealer see what is wrong with it..
Jan 03, 2008 | Olympus FE-180 Digital Camera
My digital camera shut off. Is something wrong?
Nothing is wrong with your camera. The camera has an automatic, power-saving feature that helps extend battery life. This features turns off the LCD or camera power when the camera has been inactive for a given period of time.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Pentax Optio 550 Digital Camera Logo
22 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
