Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
2nd time just simply no power, last time it started working again on it's own. Tech support had no answers. Maybe the ac adapter needs to cool down, or maybe the current in the house is slightly above or below what it needs to be to function. ?????
    Problem Solver:
  • 14 Answers
Hi there!
There are 2 possibilities I could draw out from your concern.
Firstly, it could be with the power adapter that you are using. Its possible that it is slowly getting busted. Try replacing it with a 12v adapter, if you have one. Or better yet go back to the store where you bought the router and have the power adapter replaced.
Secondly, it can also be the router itself but it is too early to say.
Try replacing the power adapter first.
Posted on Oct 01, 2009
    Sergeant:
  • 191 Answers
Please try to disconnect AC/ push reset button inside router for 30secs and reconnect AC, as it is possible that router settings got bricked during some kinda of power failure, also if that was a power surge check is AC not fryed, most routers operate @ 5V or 2,5V, there should be power listing in tech specs of router, that came in box with router
Engine heat loss power
Like...needle...haystack.
The second time it happened, did you also have the AC turned on? If so, maybe the AC compressor warmed up and seized up. But I think you would have heard your belt squealing, if that was the case.
If it only happens when the AC is on, at least you have a good indication of what to check or have investigated. Good luck.
Nov 20, 2011 | 1994 Hyundai Excel
What's your problem? the wii wont turn on
    • 1 Disconnect any accessories, such as GameCube controllers or SD cards.
    • 2 Unplug your Nintendo Wii AC adapter from the wall outlet and from the back of your Nintendo Wii. Leave the adapter disconnected for two minutes. Reconnect the adapter to the console and plug the outlet end straight into a wall outlet, not a surge protector.
    • 3 Remove the AC adapter from the wall outlet again. If the Wii has yet to turn on, the problem may lie within your electrical outlet. Plug a lamp, nightlight or something electrical into the outlet the AC adapter was connected to. If the outlet appears to work, then you'll have to test the AC adapter itself.
    • 4 Run your fingers along the AC adapter cable and visually look for any damage, such as frayed wires or a cracked piece of cable. Also look for the model number "RVL-002" and "Wii" on the adapter. If you don't see the "RVL-002" model number and "Wii" on the adapter, then you are using an unlicensed adapter, which can cause instability and power failure. If the adapter has incurred any damage, you will likely have to buy a new adapter.
    • 5 Spray air to clean out the vents on the back of the Nintendo Wii. If your Wii has been sitting for a long time, then dust and dirt may have built up around the vents, preventing the console from cooling itself. If the console cannot cool itself, it overheats and shuts down.
    • 6 Click "Start," "Internet Explorer" and visit the Nintendo repair page (see Resources) to open a repair claim. If you tried the above steps and your Wii has yet to power on, your system probably needs professional repair.
Oct 05, 2011 | Nintendo Wii Console
Dell Inspiron 1420 switch off while on at Internet site and it will not start up again when pressing the on button.
you can first try to connect your laptop to an AC power source via the ac adapter, if it fails to charge the battery, then it must be your battery died. try a relacement dell inspiron 1420 battery,which usually lasts longer and is compatibale with your dell and costs much less than the original one!
May 09, 2011 | Dell Inspiron 1420 Notebook
My Dell Inspiron 8200 will not power
remove the battery and try again with ac adapter
Mar 19, 2010 | Dell Inspiron 8200 Latitude C840 Laptop...
Powered off while using. now will not power on. tech @ bestbuy sed was bad motherboard
Take out the battery and only hook up the ac adapter. Make sure if your ac adapter has a green light that its lit. If its not lit then that means bad ac adapter.
If your laptop doesn't turn on then next step is to take out the hard drive and the dvd drive.
Try turning on the laptop again and if it doesn't turn on then that means for sure its a bad motherboard.
Dec 03, 2009 | Acer Aspire 4520-5803 Laptop
Want to play again and turn on wii Console no picture, why
You need to unplug the AC adapter from the wall outlet for 5 or 10 minutes (NOT from the Wii, you have to unplug it from the wall outlet). Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Nov 15, 2009 | Nintendo Wii Console
Amana AC model MBR2000, installed mid May 2009. When outside temp gets above a certain level the AC does not cool. fan keeps running and it keeps trying but not work. When outside air gets cooler then...
Hi it sounds to me like what actvates the 2nd stage of the compressor is not turning the compressor on when the ambeint temiture reaches the point that it calls for the 2nd stage to start it may be an out door thermostat or a ambient senser and I would request a new Tec to come out and ckeck
Aug 24, 2009 | Heating & Cooling
Toshiba a100 not starting on
Try removing the battery, and AC power, and pressing the power button down for about 15-20 seconds, and then try powering on the computer with just the AC power plugged in (no battery installed). If this works then the battery may be shot, and would need to be replaced (if you can find a suitable replacement). If it doesn't, then I would advise bringing the unit to an authorized service center to have the AC Adapter tested with a voltmeter (unless you happen to have one). The power adapter should give off a voltage of approximately 19V. If it's not, then you may simply have to replace the power adapter, either with one specifically for your model of laptop, or with a Universal AC Adapter (and you will probably need a rating of at least 75W, 90W would be optimal). If the power adapter tests okay though, then it most likely is the power coupling (the hole where your adapter plugs into. Repairs to those can usually range anywhere between $150-$300 USD for parts and labour). Hope this gives you enough information to work with, and hopefully gets your issue resolved!
May 14, 2009 | Computers & Internet
Will not boot up or turn on though it is getting power
The Charger could be bad, Try replacing that, or let charge, then try to turn on. The laptop might not boot with AC power. kinda stupid but maybe. If that doesn't work, the AC adapter is bad.
Jun 12, 2008 | Lenovo 3000 N100 0689 Notebook
Compaq Presario M2000 PC
Hi Jonee
There is no reset button on this model so I would suggest, removing the ac adapter and battery form the computer and hold down the power button for at least a min. From there reattach the AC ONLY, then try to power the unit on. If it turns on great wait for it to get to windows then slip the battery in. If it doesn't even attempt to power on, lets look at the Ac power adapter. Does it have a light on it? Is it warm to the touch? It very could be that the ac adapter may have died and the system's battery doesn't have enough power left to run the computer. If this scenario happens you may want ot call HP or take the computer to a local tech where they can test the adapter for you and determine if it is working. The last thing to check is the power pin in the notebook. IS it very loose when plugging in the adapter? If it is, that would indicate a physical problem that won't be resolved unless a tech looks at it. I hope this help.
Nov 27, 2007 | Compaq Presario M2000 Notebook
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
60 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
