Question about Dyson DCO7 Animal Bagless Upright Cyclonic Vacuum
Dyson Upright Vacuum Cleaner (Poss DC04- its green, if that helps?!?)
My Vacuum has very limited suction throught the main vacuum and when I use the attachment it is 5x too powerful.
Any ideas what the problem is?
I have removed all the parts that I can think of to check for a blockage but to no avail.
Tanya
  • 372 Answers
Hi.
Check brush roller is spinning & that belt has not snapped.
Check behind brush roller for blockages, Check clear pipe for rips or splits.
Check clear pipe for blockages.
http://dysonmanuals.llc.nu/
Chris.
Posted on Jan 16, 2008
My dyson vacuum cleaner doesn't seem to have the same suction power it used to. I have cleaned out the canister and have taken apart the vacuum head (for cleaning carpets) and it doesn't seem to be...
Hello, this is Ava with Think Crucial.
Most of the time the reason why the vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this.
You can purchase a wide variety of high-quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 08, 2011 | Vacuums
Bissell Proheat 1699 won't spray from main/min. suction
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kgj
Jul 27, 2010 | Bissell 1699 ProHeat Clear View Upright...
No suction of the water from carpet after soap is applied
Hello :
1: A vacuum pulls air through the bag, then through the tube attachment and then through the base (with the spinning agitator brush).
2:Check for signs of suction. Remove the tube attachment from its cradle and, after turning on the vacuum, put your hand to the end of the tube. Is there any suction at all? If there is a little bit of suction then you may have a clogged air tube.
3:Check the vacuum bag. It may be very full. If it is then remove the bag and replace it with a new bag. Check the suction power again. Has the suction improved?
4:Check the tube attachment. Completely remove it from the vacuum. You usually have to twist and pull the tube attachment out of place at the point where it connects to the back of the vacuum. Check the suction power again. This time you place your hand on the vacuum right where the tube used to come out of the back of the vacuum. Has the suction improved?
5:If the suction power has improved then you probably have a clogged tube. Dog hair, people hair, leaves and more can get lodged in the tube slowly over time and then suddenly block the tube completely.
6:Clean the tube by first trying to shake the debris out of the tube. If this does not work then go outside and run a hose through the tube. Use a pressure nozzle if you have one. Run the hose through one end of the tube. Then run it through the other end. Repeat until the debris is disloged. Dry the tube and then reattach to the vacuum.
7:Has suction power improved or returned to normal power? If yes then you can stop reading now. If not then read on.
8:Check the air hose in the base of the vacuum. This hose is usually pretty short and you can see if there is any blockage. If you see blockage then try to remove it. You may need to reach into the hose with a tool (like a screw driver or something long).
9:Has suction power improved or returned to normal power? If yes then you can stop reading now. If not then read on.
10:If you made it to this step then you may have a problem with the motor on your vacuum. If this is the case then you will need to take the vacuum in to a repair shop.
Things you will need :
1 Philips screw driver
1 flat head screw driver
Warning :
# Always unplug electrical devices before you work on them.
# Never work on electrical devices around water or when you are wet.
I hope this will help .
please rate !
Apr 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuum shrinks, power is still on but no suction
perhaps there is something stuck in the vacuum. Look where the hose fits in. There is obvioulsy no blockage in the hose because you have suction. Do the power brushes spin on the vacuum?? Take the bag off, and inspect the area the bag fits in for blockage.
Jer
Jan 16, 2010 | Kenmore Magic Blue 24195 Bagged Canister...
Floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
May 07, 2009 | Vacuums
Suction only with attachments but none otherwise
Remove the brush roll and then fit everything back as normal. Then switch on. Put your hand to the sole plate - if you can feel suction coming through as you would normally vacuum then it could be a motor seizure. However if you can't feel suction then there's a clog between the main dust channel and the main hose pipe/where the hose comes out the back of the vacuum.
Once that's done then put the brush roll and belt back. You may find that the belt may have to be replaced if its broken.
Mar 27, 2009 | Vacuums
No suction in the hose
see my answer to the "suction out of the handle but not to the floor" this will answer it.
Jan 20, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
When hose is attached vacuum stops
there is a clog somewhere in your hose, wand or head
a plummer snake will get it or even a broom handle
Dec 28, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Bissell clearview bagless upright
Hi.
Is this machine a Dyson or Bissell & what model number. ?
Chris.
Feb 27, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loss os self propel and suction??
Your belts are worn out. These belts should be replaced once a year.
Sep 09, 2007 | Hoover U6630-900 WindTunnel Bagless...
Dyson DCO7 Animal Bagless Upright Cyclonic Vacuum Logo
161 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Manchester Vacs
Manchester Vacs
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
