Question about Cameras
I charged the battery and now I receive the following message on the camera display "for use with compatable battery only" then the camera shuts down.
    Scholar:
  • 96 Answers
Make, model?
Some camera's have a setting in the menu, to swich them between, Alkaline, NiMh (Nickel Metal Hydride) and NiCad (Nickel Cadmium) batteries.
Cheers.
Posted on Oct 02, 2009
2006 chevy trailblazer is not charging battery. battery and alt are new
Volts slowly drop to where what quits ,The vehicle stops running ? Is the charge indicator light lit on the instrument cluster /? are any lights lit on the instrument cluster ? The instrument panel cluster (IPC) illuminates the charge indicator and the BATTERY NOT CHARGING message is displayed in the message center when the following occurs:
The engine control module (ECM)/powertrain control module (PCM) detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a serial data message from the ECM/PCM requesting illumination.
The IPC determines that the system voltage is less than 11 volts or greater than 16 volts. The IPC receives a serial data message from the body control module (BCM) indicating the system voltage.
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
The ignition is on, with the engine off
Mar 11, 2015 | 2006 Chevrolet Trailblazer
Turn off the camera and turn on again
Make sure you have a fully charged battery and turn camera and see if there is any codes or messages.
Jan 24, 2013 | Fujifilm Finepix S2980
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
I bought new batteries from local store (one from Walmart and one from Meijer) but both would not work in my Cybershot DSC-H55. On powering up, I get the message "For use with compatible battery...
the camera will only work with li-ion rechargeable batteries
any alkaline battery such as energizer will not work the camera unless you have the very expensive li ion batteries
also as with all batteries that can be recharged , you may have to charge for 4 hours before use
Mar 26, 2017 | Sony DSC-H55 Digital Camera
Camera says battery not compatible
maybe the battery is not the original battery.
you can buy cheap replaement batteries for your digital cameras.
US shop:
http://www.sales-battery.com/digital-camera-batteries.htm
UK shop:
http://www.global-battery.co.uk/digital-camera-batteries.htm
Oct 29, 2010 | Sony Cameras
Camera has failed to operate giving a "change batteries" message
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 29, 2009 | Canon PowerShot S3 IS Digital Camera
Printer will not charge camera batteries. camera screen said to go on line and look for m627-435
Did you go online and look up this troubleshooting tip from HP?  Did you make sure the batteries are rechargeable and in the correct orientation ( + and - )? Here is the results from looking up the error code M627-435 at the HP website:
Solution
  1. Ensure that the batteries are rechargeable. If the batteries are not rechargeable, replace them with rechargeable batteries.
  2. If the batteries are rechargeable, take them out and check for obvious physical damage. If the batteries are damaged, replace the batteries with rechargeable batteries in good physical condition.
  3. If the batteries are in good condition, charge the batteries using the external charger that shipped with the camera before using them in the camera for the first time.
  4. If you have tried each of the steps above and the status message still displays when you try to charge the batteries, replace the batteries.
Cause The Batteries cannot be charged status message is usually caused by one of the following:
  • When first connected to an optional HP AC power adapter or placed on an optional dock, the camera performs a test to determine if the batteries are rechargeable. If the test determines that the batteries are non-rechargeable, an status message displays in the LCD.
  • If the battery charge falls below 1.1 volts, the camera cannot detect that the batteries are rechargeable. The camera does not charge batteries below a 1.1-volt threshold to prevent charging non-rechargeable batteries. Rechargeable batteries discharged below 1.1 volts can be charged in an external charger.
    Apparently, your batteries are either seriously discharged where you need to use an external AC charger to recharge the batteries or their damagaed and need replacing. Hope this helps.
Oct 31, 2008 | HP Cameras
Battery compatibility
There's not much you can do about the problem because the problem is inside the camera. A faulty component is probably the cause. (I think its receiving more or less that the needed amount of power so that's the error with compatibility)
If still within warranty, take it back to the reseller and ask them for a replacement or get it fixed. If they refuse, ring up SONY.
Oct 02, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
I have had my camera for over a year now without a problem. It is a Sony Cybershot 7.2 Megapixels. Everytime I turn it on a black screen and the message - "For Use with Compatible Battery Only"...
Hi
There is a sentence which i cannot figure out the your wrote in your initial description of your poblem. I think it is meant to be the error message you are getting here is what i read as part of
""For Use with Compatible Battery Only&quot"
Can you try and post it again. From your response i still have te suspicion it could be the batteries, but your error message will help.
Regards
Jul 16, 2008 | Cameras
Problem
well, i just chcked my camera, and you have the right type....it could be the battery is just bad, though i don't know how to check this without trying it in another camera.
Oct 16, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Cameras Logo
51 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
