Question about American Standard Compact Cadet 3 Right Height 1-Piece Elongated with Seat
I have a American Standard Cadet three, it flushes properly but the bowl does not fill up with much water unless I hold down the handle....is this normal?
    Top Expert:
  • 12,104 Answers
In the tank check that the small white hose is not kinked or has fallen away from the center tube where the flush flapper is located the white hose goes into the center and fills the bowl
Posted on Oct 01, 2009
My brand new toilet american standard round front model cadet 3 tank not fill water
If you verify that the water supply to the toilet is turned on, push down the float on the flush valve. Water should start flowing. If it doesn't, something (such as debris) may be blocking the valve and preventing filling. The new valve could be defective - permanently closed.
Jan 11, 2013 | American Standard Cadet 3 Right Height...
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
I have an American Standard cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl is nearly gone. The flapper appears to be...
As long as the water in the bowl dosent go below the bottom rim your ok there is a trap that the water has to seal that all it needs look at the side of your toilet you will see the trap water saver
I recently bought (9 months ago ) an american standard brand model CADET 3 one piece unit and recently 1 month ago , after flushing the toilet the water fills the up the water tank but there is...
theres probably debrie in flush valve, mite also try putting food dye in tank (any color) if it appears in bowl the flapper is seeping water and activating flush valve..
Nov 21, 2010 | American Standard Cadet 3 Right Height...
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Jul 19, 2010 | American Standard Cadet 3 FloWise...
Toilet bowl doesn't hold water but tank is full
The bowl is filled up with the little hose inside the tank, it locks inside of the overflow drain. And runs water in there as it flushes to swirl the water and fill the bowl. Water seeks it's own level, and the level in the bowl is at the top of the trap. It has to hold water, unless it isn't filling or it is leaking. Check out the filler and hope the bowl doesn't have a crack in it. Hope this helps.
May 03, 2010 | American Standard Home
Toilet flushing problem! I purchased an American Standard Cadet 3 High HET toilet (1.28 gallon). When I flush the toilet, the flap will not stay up to allow the water to drain from the tank. When handle is...
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Dec 31, 2009 | American Standard Cadet 3 Right Height...
Water disappears to below the bowl inlet and stop.
adjust the float up to make water deeper....make sure no obstructions around the flapper....flapper needs to rest tight to bottom of inside the tank..flapper is the rubber peice that lifts when you push handle
Nov 17, 2009 | American Standard Cadet 3 Right Height...
Cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
May 08, 2009 | American Standard Cadet 3 Right Height...
American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
Dec 21, 2008 | American Standard Cadet 3 Right Height...
American Standard Compact Cadet 3 Right Height 1-Piece Elongated with Seat Logo
283 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
