Question about Frigidaire ATF6000ES Front Load Washer
Washer leaves spots on clothes - Frigidaire ATF6000ES Front Load Washer
    Top Expert:
  • Frigidaire Master
  • 76,846 Answers
Wipe the inside of the washer with a clean white cloth and see if anything shows up, it may be an ink pin that was left in the wash or a leaking seal that is letting grease enter the washer tube from the washer tub bearings.
Posted on Oct 01, 2009
Washer leaves white lint like spots all over dark clothes.
This happens to me as well but only when I overload my washer or when my washer needs to be ran thru its cleaning cycle.
Mar 10, 2014 | Whirlpool Cabrio Washing Machines
Leaving detergent spots. the machine fills up with water washes drains leaves detergent spots on clothes
If you dissolve the detergent in a bucket of water before adding it to the clothes you wont get this problem.
Nov 14, 2011 | Crosley CAWC529JQ Top Load Washer
Washer not washing leaving stains on clothing
It sounds like the silicone apron between your washer drum and the door has deteriorated. If that is the case, no cleaner will help you.
Best solution is to order a new one.
Jul 31, 2010 | LG WM2455 Front Load Washer
My washer leaves oil spots on my clothes
The only place where oil can enter the wash would be if the bearing seals have failed. It's a major repair, and the entire machine has to be taken apart to replace the bearing and seal.
Jul 30, 2010 | Kenmore HE2 Plus Front Load Washer
Grease /oil spots on clothes coming from washer
This sounds like the drum bearings are starting to wear and allowing grease to infiltrate through the inner seal.Does it sound noisy on the spin cycle.
May 03, 2010 | Speed Queen AWN432 Washer
Leaving black residue (spots) on clothing
Black spots usually come from the agitator shaft bearing seal which will, when worn, allow oil from the transmission to seep into the wash. Replace the seal, and maybe the upper bearing if the shaft itself will move visibly from side to side in various directions. If the machine is still under warranty, take advantage. Hope this helps!
Apr 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer is leaving dirty spots on clothes
If you use fabric softener it may be from the softener. Dilute your softener 50% before pouring it in.
Sep 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leaving dirty marks on clothing
Try removing the water hoses and find the screens in each end.. If clogged with gunk - that could be the culpret..
Jul 23, 2009 | Washing Machines
Leaves spots
YOUR BEARINGS ARE GOING THE BLACK SPOTS ARE GREASE FROM THE BALL RACER RING THEY SIT IN, IT WILL ONLY GET WORSE & EVENTUALY YOU WONT BE ABLE TO GET IT OUT OF YOUR CLOTHING & THEN YOU DEVELOPE A PUNGENT SMELL THAT WONT GO UNTIL IT IS FIXED, YOU CAN CHANGE THEM YOURSELF BUT IT IS NOT EASY FOR SOMEONE NOT KNOWING WHAT THEY'RE DOING, SORRY, I HOPE THIS HELPS A BIT...
May 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaves spots on clothing
It most likely is fabric softener. You need to clean dispenser with hot water, if this has one. In real cold water the softener won't disolve properly and will cause this to happen.
Oct 08, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire ATF6000ES Front Load Washer Logo
390 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
