Question about RCA HD56W58 56" TV
I have a Rca HdTv Model#HD56W58 No pic and sound green power light comes on and I have a high pithced squeel Is that the High voltage Transformer
  • 1 more comment
  • GatorJ75268 Oct 02, 2009
    I had a tv repairman tell me that it sounds like the High voltage transformer or the splitter could that give me the same thing
    how would I know if the lamp has gone bad
    I have a RCA HDTV Model HD56W58 I have no sound or pic green indidcatot light comes on in front and I have a high pitched squeel I have had many people say HT compasitors and the other a lamp and the other HVT Splitter ot the HVT transformer can you help please
  • 3,267 Answers
This is a common problem in most HDTV's is the RCA FL231 Convergence Fuse,RCA Part No. 259213 has to be replaced.
Direct replacement FL231 convergence fuse (RCA part# 259213 - 400mA, 125V) Thompson ITC222 chassis.
This is the part that commonly fails in the ITC222 chassis that causes the convergence to be too far out of spec.................sodeep
Posted on Oct 02, 2009
    President:
  • 1,462 Answers
It sounds like an HT ( high tension) Capacitors leak
This is often caused by the lead becoming partly unplugged ( being bumped or moved) and because of dust buildup it arcs making a high pitched hissing whistle.
The lamp may also have been affected by the HT leak.
Just open the TV and look the power supply board for any leaked or bumped HT capacitors, if found try replacing them.
After replacing inspect the lamp. try changing if necessary
please leave me comment, if you need further assistance
RNJ VINODKUMAR
Posted on Oct 01, 2009
  • Vinod Kumar
    Vinod Kumar Oct 02, 2009
    Just check whether you get illumination inside the TV, if its completely dark inside.It ststes problem with the lamp..
    First change all the HT capacitors and check..Mostly it gets rectified after changing the HT capacitors
    RNJ VINODKUMAR
The blinking of death.
set is trying to come on but not making it.
Most common issues with this model are bad connections around the high voltage transformer or on that same board.
A few will also have the High Voltage splitter at the very front of the set behind the front grill fail---a faint arc when you try to turn on.
8_30_2012_2_57_40_pm.jpgHigh voltage transformer
Aug 29, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA HD52W59 problem
set is prone to two problems: high voltage splitter at front of set behind speaker grill arcs-------also set does have parts on HV board that do the same thing---HV transformer feeds voltage to the splitter.
Jun 07, 2012 | RCA HD52W59 HDTV Projection Television
Can't get a picture on tv
high voltage issues.
needs a power supply/deflection board or maybe a flyback transformer
200-300 $
May 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca hd52w59 chirping sound and light 3 times no picture
chirping sound is a short of some kind, could be the flyack or horizontal output, could also be a bad picture tube or power supply capacitors, you really need a tv repairman to troubleshoot this.
Sep 17, 2009 | RCA R52WM24 52" HDTV Projection Television
I have hdtv rca d52w19 green power lights shows
Hello Chris this problem is coming from your high voltage circuit which consist of the flyback transformer and the horizontal output circuit, the most common problem when it is acting this way would be bad soldering on the flyback transformer or defective transformer but keep in mind it can also be caused by the horizontal circuit or a faulty lamp as well can cause this problem, what i would recommend is to have a tech come out to service your tv set this should not be an expensive repair since most of the time it is just bad soldering on the flyback thank you hope this helps.
Aug 27, 2009 | RCA D52W19 52" Rear Projection Television
RCA 57 inch hdtv Model#HD56W58 has sound but no picture.
WOW...had a high pitch noise, came and went...got worse as time wore on. Would shut off the set, times it cleared times it didn't. Warranty folks set out a TV repairman--said he had worked for RCA exclusively for years...anyway, explained that the 1k hertz noise was a known issue with the HD56W58 and that RCA’s published fix was "nail polish" applied on some board, had something to due with power and vibration...long story "presto" noise gone...but after 6 or so months we began to hear it again—say it ain’t so, but yes the high pitch was back. Same repairman, this time bigger problem...along with noise, the network card is broke and Fry’s Electronics (Irving, TX—hear that Corporate HQ at San Jose…your Irving store needs to be leased in and tote the company line...where's the customer satisfaction???) is balking at a “equal” replacement, they see it as take the less than equal product or get store credit…good luck & wish me luck with the equal replacement they tout when pushing the warranty.
Mar 15, 2009 | RCA HD56W58 56" TV
RCA HD56W58
RCA HD56W58 Rear Projection TV quit today. Resistor burnt up r14705. Power light goes on and high pitched noise but no picture or sound.
Nov 09, 2008 | RCA HD56W66 56" HDTV
TV turns on can hear sound then shuts down.
Did you check the high voltage transformer and the high voltage splitter (distributor). RCA HVT is known for going bad. i have the part number for both if needed. 5520-559-5774 john
Aug 14, 2008 | RCA HD56W58 56" TV
RCA model hd56w58
the part number for the high voltage transformer, according to another post for this tv is 258512. See below:
noavatar_s.gif jdenton77
Rank:nonexpert_s.gif Apprentice
Rating: 85%, 1 votes
Yes, i had the same issue. High voltage trans. and the HV distributor (splitter) goes bad on there tv, they are known for that. I have the part numbers for the HVT p/n 258655 and HV distributor(splitter) p/n 258512. The two p/n are for HD56W58 proj. tv
Jul 08, 2008 | RCA HD56W58 56" TV
RCA HD56W58 56" TV Logo
279 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
