Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Oven not working -makes a buzzing sound when turned OFF!
Oven does not heat up properly, then when I turned it off it makes an annoying buzzing sound. I turned mode to "self-clean" and buzzing stopped. This is weird. Oven only 3 years old.
    Scholar:
  • 146 Answers
You just need to adjust your door latch assm. Try putting a little oil on the latch and arm. The sound you hear is the solenoid trying to pull the latch arm all the way back to lock the door. Even though it is pulling the arm back and the door locks it may not be all the way back. A little lubrication will fix the problem.
Posted on Dec 21, 2007
  • Rick Viking Jun 06, 2012
    Wow! Slammed the door on my Viking and who would have guessed? The oven started working! No more buzzing... no more self starting! Glad I tried this instead of using the sledge hammer. Thanks KELLY!!!!!!!!!!! Now to figure out how to adjust the hinges correctly for no future problem... got a simple solution???
My DCS WOS-230SS top wall oven begins to heat up normally but then stops heating, the fan comes on, then begins heating up again. Got to 170 then went no higher. Could it be the element?
This is a tough question because we haven't mention the make and model number you should add that so we can help you better but normally if the top oven is not working properly it may have thermostat problem or it could also be control panel problem can you tell more information especially the make and model
Sometimes you can take it out and it's not working properly and take that oven and put it in self-clean mode and it might fix problems
Mar 27, 2018 | DCS Ovens
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Why doesn't oven work after using the self- cleaning mode?
Check for incoming power; you may need to change the heater element.
Sep 11, 2015 | Whirlpool GBS307PD Electric Single Oven
When I turn on the self cleaning oven, it makes a loud buzzing noise. Is this normal? If not, what needs to be fixed and how do I do it?
The buzzing sound comes from the relays located on the control board. Remember, the oven gets very hot during self clean, so the control works at full speed to get all the elements working.
Jan 03, 2015 | Kenmore 30 in. Electric Self-Clean Single...
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
Buzzing sound
Maybe the knob might be a bit rusty, or it's always like that. It's also a good idea to get people to check the knob.
Nov 28, 2013 | Bakers Pride EB-2-2828-S 2083 - 28-in...
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The oven goes on, carousel and timer works, but no heat. The oven felt warm on sides at first. Unplugging it, waiting awhile, turning it on did not correct the problem.
The magnetron circuit has failed. If it makes a loud buzzing sound when you operate it, means that the magnetron has shorted out. The replacement cost for the magnetron is almost as much as a new oven, so it does not make sense to get it fixed. Sorry.
Apr 15, 2011 | Sharp Microwave Ovens
Everything works but "heating". Makes grinding
The loud buzzing sound with no heating, is symptom that the magnetron has failed in your oven. Magnetron replacement cost are almost as much as new oven, so it does not make financial sense to repair. Sorry.
Jan 21, 2011 | Panasonic Microwave Ovens
Owner's manual re self clean feature Kithcen aid Superba27 self clean double oven purchased 1988 Cannot get it to turn on and heat. The Lock light does not go on and no heat is generated.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 17, 2011 | KitchenAid Ovens
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
744 people viewed this question
Top Viking Kitchen Ranges Experts
Steve Allison
Steve Allison
Paul Carew
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
