Question about Kodak EasyShare DX7590 Digital Camera
The camera do'nt "see" the 4GB SD HC card, try to formatting but without succes and return to try formatting or "no external card"
    Brigadier General:
  • 11,967 Answers
Check your manual to see if your camera accepts SDHC cards or just SD cards.
Posted on Oct 01, 2009
How do i format sandisk 4gb micro sd hc
You shouldnt have to format it.Though it is possible. first check and make sure the drive is not locked. There should be a smll switch on the side of the sandisk. Second be Sure your device supports HC cards. Read This tip carefully If its your computer and it has a HD compatible slot insert the drive, open my computer , you should see its new icon as a drive. Right click on the drive and select Format from the list. But, as a reminder if your device supports the HC or XC format drive, it should work without a Format. Hope that helps ya, Gurvy
Sep 01, 2010 | SanDisk 4GB microSDHC Memory Card
Have a Kodak EasyShare C743, bought a SanDisk, won't format
Your camera was designed before the SDHC format came out. Sorry, your camera can only use standard SD cards, those usually 2GB or less. An SDHC card will not be recognized properly by your camera. If you really want to use a 4GB card, do a Google search for SD and "non hc", with the non hc in quotes. Believe that Transcend makes one.
Apr 24, 2010 | Cameras
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
Jan 02, 2010 | Canon PowerShot A530 Digital Camera
A530 has message "memory card full". tried 2 cards same results.
1. First, try to format both the memory cards using a PC/Laptop.
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 21, 2009 | Canon PowerShot A610 Digital Camera
I have a canon powershot SD400 elph. Camera menu
Dec 12, 2009 | Canon Cameras
I have loaded a new memory stick and get a message "memory card error" I have since tried another card and get the same maessage. Any idea waht the issue is.
Well if your camera is an SD600, I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
Nov 17, 2009 | Canon PowerShot SD600 Digital Camera
Inserted new memory card error message:memory card error unable to access format under menu
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Hi,just bought a 4gb sd card for my digimax s600 but it won,t work.when i switch on camera, screen says..format..yes.confirm ok.when i do this i get check sd card . i put in old card it works fine??..
Does your camera support SD HC? Anything above a 2gb SD card is concider a HC; so if your camera can't support HC format then you can not use that card.
Sep 09, 2009 | Samsung Digimax S600 Digital Camera
SanDisk 4GB MicroHC card says card is dirty clean or format.
do you have a SD card reader for the computer? if not, getting one is a good idea. you can try putting the card into your computer to copy your pictures into your computer before formatting. And if you get the card reader from best buy. if this doesn't work you can always return it.
May 08, 2009 | SanDisk 4GB microSD High Capacity Memory...
Kodak EasyShare DX7590 Digital Camera Logo
124 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
