Question about Codemasters Damnation – Xbox360
When trying to use the elevator the game lets me use the first lever to open the door. The lever inside does nothing or one of the characters is blocking it
    Problem Solver:
  • 7 Answers
You cant use it till u beat the campaign
Posted on Mar 20, 2010
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
Im a girl and no nothing about cars. i have a 95 olds cutlass supreme. both of the front doors will not open from the outside, yet work fine from the inside. the the locks work fine to. any ideas
It is not really normal on front doors, but when the door is open, if you have a look at the latch on the door you may see a little lever. This is called a kiddy lock, well it is here in NZ, it prevents the door being opened from the inside accidentally by fidgeting little hands. Try moving the lever to its opposite position.
Feb 27, 2012 | 1995 Oldsmobile Cutlass Supreme
Drivers side front door will not open from inside or outside even using the key
Sounds like the clips that hold the rods, that operate your inside/outside door handles have come loose. You will have to get the door panel off...but first...you'll have to get the door open. OK...where your inside door "lever" is located....there is a plastic cover behind that lever.....also, there might be a small plastic access cover... over the screw that holds on this larger cover in place. If so....pop the little access cover off and there will be a screw behind it. (keep in mind...this is behind the inside door lever you pull on to open the door) remove the screw...remove the cover...you should now be able to see where the rod has come loose. if you cant grab it with your fingers, get a pair of pliers and pull forward ( toward the front of the car) to open the door. Make sure the door lock is off also. You may find the clip that holds the rod to the lever is broken or the rod has just fallen out of the clip. Sometimes, you can wire the clip into place so it dosnt come loose again. At this point, you will want to remove the door panel....because the "outside door lever...rod...is also loose...in which case you will need access to the inside of the door to fix it. Just remember, you only want to this once...so while in there...fix it right....
Theroadisalover
Try to post back and let me know If I helped you solve your problem. It will help me with my rating....! Thanks
Jan 01, 2011 | 2001 Saturn L-Series
Power lock, driver door, stuck in lock position. Can't unlock with power switch, slide lever, or key. Hear click but does nothing. Passenger side is fine.
Take a spray can of WD-40 or similar penetrating lubricant, and attach the little nozzle that comes with it. Stick that nozzle inside key hole as far as you can get it, and start spraying. Soak it good, and draw nozzle out slowly as you keep spraying, so that you get as much in all areas inside the tumbler as you can. Now open door and spray all around latch area, in behind, down the sides, and give it a good soaking as well. Try to also aim spray nozzle at back of key tumbler if you can from that hole where the latch is. Now let it sit for a 10 minutes or so to start working, then try moving lever, as well as try turning key in door as well, but don't force it to the point that you bend the key. Keep trying if it doesn't work at first, and give a little more spray each time, until it finally loosens up. Let me know if you get it moving.
Dec 28, 2009 | 2000 Chevrolet Silverado
Gas door wont open when pushing release lever, Trunk release works OK when pulling on same lever.How can I open Gas door without pushing on lever? What is the fix? Has enywone out there had this problem?
Try removing the plastic lever handle to see if it will let you push the lever further towards the floor resulting in more tension on the (hopefully not broken) cable.
Take a plastic knife like you would get at Wendy's (or anything you can think of that would work better) and wiggle it in the center of the right side of the fuel door. You're trying to depress a trigger and pop it open. Forcing can bend the inner latch but it can be bent back. After you get it open you'll need to do some adjusting or diagnose if the cable is broke. Even though it's the same lever, it's two cables.
Oct 01, 2009 | 2000 Honda Accord
Sometimes character will get "stuck"
is ther lots of ram and stuff delete them
Jul 14, 2009 | Microsoft Xbox 360 Console
Describe your my Mitsubishi endeavor 2004 back door doesn't open Problem
Does this not open from inside or outside or both.
If it opens from the inside and not the outside look at the door opening near the latch. Look for the small lever "child-lock" just move the lever in the oposite direction.
If the door doesn't open from inside or outside I would ask has anyone try to unlock the car using a "slim-jim" if so they may have caused the lock rod to come off the latch on the inside. You'll need to remove the door trim panel and see the the rod has come off. With any luck it will just pop back on if the nothing is broken.
Jul 08, 2009 | 2004 Mitsubishi Endeavor
Driver side door won't open from the inside.
remove the inside door panel reach inside and, reattach the clip to the inside door lever rod
May 22, 2009 | HP Compaq Presario V5204nr Notebook
Passenger side rear door will not open from the inside or outside. I don't know how to fix get it open let alone fix it.
could be the door lock arm has come off the lever inside the door, It will be hard but if you can remove the door trim from the door by removing the armrest and handle and going round the perimeter of the trim levering the trim from the door with a flat blade or even a screwdriver to pop the clips out of there plastic retainers and remove the trim it will give you access to the inside of the door once you cut through the plastic weather seals over the large openings in the door.
You may be able to see the problem then which I think will be the door lock arm in the door has come out, that is all it will take to stop it from opening
May 12, 2009 | 2002 Chevrolet TrailBlazer
Codemasters Damnation – Xbox360  Logo
44 people viewed this question
Top Codemasters Video Game Consoles & Games Experts
James Wishart
Nikki  Mclean
Nikki Mclean
SirEbrum
Are you a Codemasters Video Game Console and Game Expert? Answer questions, earn points and help others
