Question about Krups Allegro FND111 Espresso & Coffee Maker
Espresso maker won't brew.
I fill the espresso maker up with water and it won't brew, sometimes I get a shot or so, but I fill the water up ALL THE WAY. I've already tried rinsing out the inside and brewing vinegar water and the problem is almost worse now. I've only had the espresso maker for a couple years. PLEASE HELP!
  • 3 Answers
Most likely it is an internal problem, such as a broken valve or nozzle.
Posted on Oct 31, 2009
Sunbeam em6910 brewing does not stop
Use a bigger glass or cup . easiest fix I can thnik of
Jan 10, 2015 | Sunbeam Cafe EM6910
I have two older style used Bunn CWTF coffee makers. Both if them have the same issue. When the unit is not even plugged in or turned on, and the water source is turned on, water shoots from the fill
the plunger for ur solenoid valve assembly might be stuck in open position ... ur click sound maybe came from ur funnel lock during brewing. water shots from the fill or oveflow cup due to contoniuos supply of water , try to close ur main water and c if water will also cease
Sep 13, 2014 | Bunn CWTF Coffee Makers & Espresso...
I get lots of watered down coffee. It brews 3/4 cup but it is so watered down. We have descaled etc. I want a thick expresso like taste. This is on a large cup setting Help?>
HI
When you run a lot of water through just a little coffee it gets water down. Try making 2 meduim cups instead. When they make espresso its 1 tablespoon to 1 oz of water. Your running 6 oz of water through the same amount of coffee, and its going to be weak. Program you buttons for 2 shots to fill your cup and it will be pretty strong.
Jan 25, 2011 | Gaggia Syncrony Espresso Machine
X1 trio makes huge shots, at the 3rd position it will nearly fill a coffee cup, at the middle it makes a double (about 4oz, and so on. What is wrong with it
Hi
The trio is set up for pods. There is nothing wrong with it. The positions on the brew head are for different shots. The 3 rd position lets a lot of water through, and the 2nd one lets less and the first one lets the least water through, and makes the strongest coffee.
Apr 19, 2010 | FrancisFrancis! X1 - Stainless Steel...
I have water leaking from under and I cannot see where it is from. I have taken the brew group out and cleaned but it still appears.
try this:move brew unit and you will see white brew valve,clean inside sometimes coffe stuck inside and dont draining water from valve in tray
Aug 20, 2009 | Saeco Vienna SuperAutomatica Coffee...
How to clean an espresso maker
Here is the user manual with extremely detailed cleaning info. If it wasn't cleaned before last use, you probably have mold buildup, etc., so go ahead and go through ALL of the cleaning instructions:
http://www.focuselectrics.com/supportdata/L5563G_55108-3in1_All.pdf
-Tha Mp3 Doctor
Mar 19, 2009 | West Bend 55108 Espresso/coffee Maker
"Fill water tank" prompt
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Oct 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
Sissling when making espresso
First of all, do you steam your milk first then immediately brew the shot? If so, that is your problem. When you depress the steam switch, the temperature elevates way past what is optimal for brewing espresso. If you try to brew immediately after steaming milk or using the hot water feature, that would definitely be why your espresso sizzles. Your shot will likely come out burnt tasting, thin and just plain rancid.
Either brew your shot first (learn temperature surfing for your best shots), or immediately after steaming milk, turn off the steam switch, depress the brew switch (without portafilter in place) for a few seconds until no steam comes out- only water (wait till you don't hear the sizzling sound). Hope this helps.
Aug 07, 2008 | Rancilio Silvia Espresso Machine
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
Wet Steam? Weak Espressos
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Sep 11, 2007 | Saeco Vienna SuperAutomatica Coffee...
Krups Allegro FND111 Espresso & Coffee Maker Logo
271 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
