Question about Whirlpool Dryers
Will not start - Whirlpool Dryers
  • Whirlpool Master
  • 2,605 Answers
Hi, First unplug the unit from the wall. It sounds like either an activated kill switch (belt broke) a broken door switch, or possibly a open thermal fuse. The door switch is the easiest to check. Do you hear a "click" when you physically push the switch and let it out ? Is, it is likely ok. The belt is fairly easy too. If you reach inside the drum and turn it by hand does it feel easy or is there drag ? Feel for airflow at the vent while spinning tge drum by hand, if there's air flow, the belt is ok. The thermal fuse requires you to remove either the back panel or the front access panel (depending on model/design) look for a small white plastic item with two wires going to it. It should be located on the exhaust/blower housing. If you ohm it out that will verify if it's open (no good) or closed (normal/good). Hope that helps good luck
Posted on Oct 01, 2009
Volvo v40gdi sometimes won't start but starts fine from cold when trying to start it chokes and struggles if I remove air filter assembly it starts fine,
To troubleshoot the issue, click the link below:
Car Repair Diagram
http://technoanswers.blogspot.com/2013/03/car-repair-diagram.html
HOT/WARM START ISSUE
Its a hot start issue.
Can be related to low fuel pressure or problem with crank sensor.
Also it can be weak battery or starter.
But possibilities are to be inspected to confirm what exactly it is.------
To troubleshoot and confirm the issue,i suggest you refer few solved help links with similar types of problem like yours:------
Click the link below:------
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
Multiple problems on car: Car runs hot, A/C blows hot and car starts surging?
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
Delay starting on Toyota Prius?
http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
Honda car will not start intermittently?
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
Vehicle Starts, Runs and Loses Power
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
Intermittent starting issues on Volvo 760?
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
Car starts and cuts off immediately?
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These details will help.
Thanks.
Mar 14, 2013 | Cars & Trucks
I have dodge ram 1500 v8 no start
CAR NO START PROBLEMS:-----
It can be the issue with weak battery or faulty battery or if battery is ok,then its faulty starter causing the issue.
From start to end troubleshooting these problem i suggest you to click the link below and follow its procedure:-----
What to Do When Car Turns Over But Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
Car starting issues?
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
Car Starting Problems
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse Blows?
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
http://www.howtorepairguide.com
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Car will start to chugg and then die and sometimes wont start , engine light comes on when this starts happening
Get the vehicle scanned,there is error code stored in ECM,that code will tell what part exactly to look,for:----
But other then these for starting troubleshooting for these problem,
These will help.
Thanks.
Nov 28, 2012 | 2000 Pontiac Bonneville
2007 Jeep Liberty won't start. See Video.
1989 Toyota Pickup Truck: Turns over but not start? http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start? http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
2001 Toyota Prius will not start? http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start? http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html ------------- Mitsubishi will not start
These will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
2001 mercury mountaineer starts fine but sometimes won't start at all
These will help.
Thanks.
Nov 25, 2012 | 2001 Mercury Mountaineer
I cannot use cheat codes of call of duty 2
Select "Game Options" at the main menu, then choose the option to enable the console. Press [~] to display the console window then enter developer 1 as a command to enable cheat mode. The "Load" button will now appear. Click it and select the desired level. After the level loads, press ~ to display the console window again, then enter devmap as a command. Press ~ during game play to display the console window, then enter one of the following codes to activate the corresponding cheat function:
god ... Player invulnerability on/off
give all ... Player accrues all weapons
give ammo ... Player accrues all current weapon ammo
ufo ... Player may swim/fly through game world
noclip ... Player may clip through environment
notarget ... Player is invisible to enemy entities
moscow ... Start on the map Red Army Training
demolition ... Start on the map Demolition
decoytrenches ... Start on the map The Diversionary Raid
decoytown ... Start on the map Holding The Line
elalamein ... Start on the map El Alamein
eldaba ... Start on the map The End Of The Beginning
tankhunt ... Start on the map Repairing The Wire
trainyard ... Start on the map Railroad Station No. 1
downtown_assault ... Start on the map Downtown Assault
cityhall ... Start on the map Stalingrad City Hall
downtown_sniper ... Start on the map Comrade Sniper
libya ... Start on the map Crusader Charge
88ridge ... Start on the map 88 Ridge
toujane_ride ... Start on the map Armoured Car Escape
toujane ... Start on the map Retaking Toujane
matmata ... Start on the map Assault On Matmata
duhoc_assault ... Start on the map The Battle Of Pointe Du Hoc
duhoc_defend ... Start on the map Defending The Pointe
silotown ... Start on the map The Silo
beltot ... Start on the map Prisoners Of War
crossroads ... Start on the map The Crossroads
hill400_defend ... Start on the map The Battle For Hill 400
hill400_assault ... Start on the map Rangers Lead The Way
bergstein ... Start on the map Bergstein
breakout ... Start on the map The Brigade Box
newvillers ... Start on the map The Tiger
rhine ... Start on the map The Crossing Point
Feb 28, 2010 | Activision Call of Duty 2 for Windows
Dryers Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
