Question about Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air- model # SVE47600B
My oven is showing F5 and FC. I went to turn it off and it wouldn't turn off and the fan sounded like it couln't make up it's mind to run or not. I had to disconnect it to stop the beeping.
  • jaymicdague Mar 01, 2009
    getting fault error, FC, warning, beeping
I was cleaning the oven and leaning on the oven door and now when I close the door it is hard to close
Posted on Mar 13, 2008
Jenn air gas electric grill range with convection oven making beeping sound showing -FC- code
FC is a communication error caused by poor connections with the wiring between the logic and relay boards in the unit... Disconnecting and re-connecting the wires and looking for / reflowing the solder joints behind the header connectors will fix your issue
Jul 19, 2016 | Jenn Air Kitchen Ranges
Jenn-Air oven shuts down after FC and F5 errors
Their was a good possibility that the solder could have been lifting of the contact points on the board, if the symptoms return i would check this, along with the said cleaning method :)
Mar 15, 2014 | Jenn-Air SCE30600 Slide-In Electric...
JENN AIR MODEL SVE47600B DOESN'T CLEAN AND HEATS UNEVENLY
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 04, 2011 | Kitchen Ranges
I have a Jenn-Air Model SVE47600B/water boiled over
Start by looking at your owners manual which can be downloaded here if you lost yours:
http://www.servicematters.com/maytag_library/docs/16010191.pdf
On page 23 Also called page (1-3) you will see a test procedure, do that first then check the fault code page. Page 26 will detail what the fault codes mean.
F- means there is a fault between the communication boards (replace display board), while FC says the same thing but the result is the different and says replace the PRB. What this tells me is that the problem isnt the board or prb, but that moisture in the area is causing a short, and should be cleaned out with alcohol. If the error code were constant, the board would be bad. In your case, it changes after replug, so I suspect that a thorough clean of the control board area will be all thats needed.
Mar 23, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air model #sve47600b. Today put new display control panel in. Didn't fix the problem. The display now works, but the oven light and fan will not stop running. Also the touchpad doesn't work. If it...
Make sure that you properly plugged in the keypad cable. There is the wide connector that brings all the keypad touches up to the display board, and there is the small 4-black wire connector that brings power to the control board.
For future reference, we repair electronic control boards at www.fixyourboard.com, maybe we can help you in the future.
Oct 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Re: Jenn Air #svd48600b Gas Stove Top works... Oven and Broiler not working(Elec.) I replaced Electronic oven control assy...It works correctly, but never gets Hot!! Any ideas??
Having a problem with the stove on this Jenn Air svd48600b.
Often with the oven warms up to 350F it starts beeping at and shuts off.
It flashes either just an FC error code, or FC and F5.
It is often possible to get the oven to work again if you wait 10-15min and cycle the power.
I imagine something is wrong with a heat sensor? The temperature sensor responsible for displaying temperature on the control panel seems fine though.
One other detail, even when the oven doesn't shut off at hot temperatures, the fan comes on (at around 220F) and stays on for over an hour after the oven is turned off.
Does anyone know if there is a different temperature sensor that might cause this? Is there a specific electronics board that may be leading to this problem.
when it heats up.
Aug 24, 2009 | Jenn-Air Kitchen Ranges
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Feb 23, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JES9860 Electric Kitchen Range Logo
526 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
