Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Similar problem ive tried all options sugested on other sites, switch off info menu mute switch on but to no avail any body hep ????
  • ga56uk Oct 01, 2009
    on attempting the retune of the digital channels, it appears the d menu button isnt working a message stating not available comes up. i can get 1 digital channel but that freezes
    it appears a reset is required and have been advised to try the method described above but its not working
  • Jim Krause May 11, 2010
    Describe the problem your having?
  • 6 Answers
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Posted on Oct 05, 2009
    President:
  • 1,653 Answers
TRY PRESSING THE DTV / TV BUTTON TO GET THE MENU.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Posted on Oct 03, 2009
How can I open the service menu?
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons.
PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Hidden Secret Service Menu Codes for Sony Samsung LG and Philips TV
TV Service Menus Hidden features you didn know about
Jan 31, 2016 | Televison & Video
I need the code that will tske my samsung 40" out off hotel mode
hello,
To switch off hotel ode on samsung, enter:
1. On standby press info-menu-mute-power or,
2. press mute-1-8-2
After service mode appear, Choose option block,
Fine Hotel mode, change to off.
If in option block you can't fine it, try open other block.
Good luck.
Apr 16, 2011 | Televison & Video
Reset code for le32r73bd - OTHER THAN INFO, MENU, MUTE, POWER
Jan 2016 --- Panzo's solution worked a treat, just remember to go into analogue, press buttons quickly, navigate to reset (option#12) and press left arrow which will remove the snow effect in analogue.
Thank you, and the rescanning worked without a hitch. Whew thanks again
Aug 02, 2010 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Pc cant get past the boot menu
By the sounds of it you are going to have to restore your pc with the recovery disk you got with it. I had a similar problem and contacted Fujitsu and thats what they told me to do. There is no recovery from boot up without the disk
Jan 13, 2010 | Computers & Internet
I have a LCD SAMSUNG LE32B450C4H. None of the controls are available to adjust contratst, luminosity, sound, ... What can I do?
I have the same model, try to enter the service menu following these steps: - Power off the TV through the remote. - Press this sequence of keys: Info, Menu, Mute, Power on. The service menu will appear.
In the service menu, disable the hotel menu. If it is enabled may be the cause of your problems.
NOTE: change options in the service menu at your own risk.
See you.
Jan 02, 2010 | Samsung LA32A450 32 in. HD-Ready LCD TV
Samsung lcd faults
Found this on FixYa and it worked:
I had a similar problem and the way to solve this is to reset the set from the remote. Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Peter
Mar 10, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Frozen digital screen
Dec 21, 2007 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Pioneer head unit
You have to have a "Car Kit" installed for your cellular phone, either Bluetooth or not. It would have a wire that would be connected to your Head Unit to enable the Telephone Mute or Att, as you choose.
If you dont have a car kit, it is of no use to you.
Best of Luck.
Nov 14, 2007 | Pioneer DEH-P6900UB CD Player
Built in freeview locked up in tv
I also got a black screen! I then turned the TV off, pressed TV and while it was lit, quickly pressed info, menu and then mute. Then switched the tv back on and amazingly......the menu was there. Go to item 12 and reset. I am please to say that we are back in business,
Jul 12, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
323 people viewed this question
Jerry Greenberg
Jerry Greenberg
