Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Does the T8602C1095 have an anticipator that may need adjustment when the temperature set is exceeded, eg we set at 70 and it goes to 71-72 and then need to manually shut down system.
  • 70 Answers
That is how they work. ther is a 1 to 3 degree variance up or down.it probaly does not kick back until 67 or68 degrees. a two stage furnace will keep a more steady temp.
Posted on Oct 04, 2009
What should the heat anticipator be set at on the thermostat?
The purpose of a thermostat heat anticipator is to "de-sensitize" the thermostat so that when actual room temperature is hovering close to the set temperature on the thermostat, the thermostat switch won't keep switching the air conditioner or heating system on and off too often - which can damage the equipment.
If you are replacing an existing defective thermostat with a new one, simply, set the anticipator to the same setting as the old one- as long as they are of the same manufacturer and model.
If you don't have the old one to match the new thermostat settings to, then you need to measure the thermostat's circuit using an ammeter.
In order for the thermostat to operate properly- you must adjust the heat anticipator resistor to match the current of the gas valve or relay on an oil-fired burner..
Another option is to install the T-stat using the factory default setting.
Since you did not mention the make and model number of the T-stat you are using, I cannot be more specific.
Feb 12, 2017 | Heating & Cooling
Tip
How do I Set the Thermostat Anticipator
If you have an older thermostat that has a heat anticipator in it then there are some things that you need to know about setting it and what it actually does.
First the function of the heat anticipator is to fake the thermostat into feeling the room temperature as hotter than it really is. The heat anticipator is actually a variable output heater inside your thermostat. The amount of heat that it actually produces is very, very small. This heat does, however, make a difference in how the room temperature feels to your thermostat.
If no extra heat is made inside the thermostat it will not react quickly enough to shut off the heating source. This will make the room “overshoot” the set point of the thermostat.
By heating the thermostat up very slightly it then shuts down the furnace or heat source before it actually reaches the temperature set point. This will allow the left over heat to go into the room and raise the temperature to the set point by the time it is all used up.
If you are experiencing wild temperature swings or the room temperatures are either not getting to the set point or going over the set point then the heat anticipator either is not adjusted right or it is burnt out and not working at all.
There are a couple of different types of heat anticipators. They will usually look like one of these.
If your heating is running too long then you will need to adjust the setting to a lower number. If you are not getting enough heat then go to a higher number. All you are changing when you do this is the amount of the heat coil you are using. Make small adjustments to the anticipator and then give it at least a half day before making more adjustments. Small changes can have a big effect if the heat anticipator is working correctly.
You also can set the anticipator by checking the current draw of the system. To do this you need to use an amp meter and measure the current draw of the heating unit when it is running. Then set the heat anticipator to the corresponding number of the current draw. This will at least get you a good starting point and some fine small adjustment can be made from there.
For more advanced digital thermostats there are cycle change features that do what this heat anticipator does in older thermostats. These often incorporate many things in determining the cycle length of the heating. These thermostats will not have a heat anticipator setting.
Like many things when it comes to your comfort, all people feel things a bit differently. You need to make the changes to the thermostat so that YOU feel comfortable. There is no right way it has to be done. Make it work for you and adjust the thermostat so that you are the most comfortable!
http://www.fixya.com/support/r3892721-programmable_honeywell
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3584298-air_conditioning_programmable_thermostat
http://www.fixya.com/support/r3898732-lux_thermostat_500
on Jan 30, 2010 | Heating & Cooling
Bryant Furnace starts up then shuts off
If you have a standard thermostat and not a digital stat, the problem could very well be the 'heat anticipator' setting on the thermostat sub-base. It is a variable resistor that has to be adjusted to match the amp draw of the heating control circuit. In the heat mode, the heat anticipator 'warms' up the thermostat because of the heat generated through the system controls and causes the thermostat to 'anticipate' room temperature setpoint just a little before it really gets there.
If set too low, the result is a short cycle, if set too high, the result is an overshoot in setpoint temperature. The average setting for the anticipator is .4. You should see a very thin 'wire wound' flat resistor under the cover with a thin metallic pointer that physically slides from left to right or right to left. The pointer is pointing to its 'setpoint'. Adjust it up .1 or .2 from its current setting and observe operation for a week or so to see if any appreciable change has occurred.
Mar 22, 2015 | Bryant Heating & Cooling
Toner not stuck well on paper and can be easely erased by hand
Sounds like you have bad toner. or fusing area not getting hot enough to fuse to paper. I would try another toner cartridge. If problem goes away. Bad cartridge.
Feb 21, 2014 | Ricoh Aficio Mp4500 Mp3500 Cl7000 Ap3850c...
How do I adjust the heat anticipatory to its proper settings
Look on the gas valve. Or post the make and model
Mar 21, 2013 | Heating & Cooling
My themorsat stop working,and I replaced the batteries.
see this causes and fix it. God bless you
Furnace Produces No Heat Possible Causes
Possible Repairs
  • Remove cover of thermostat and loosen screws holding unit to wall. Level the thermostat. Re-tighten screws and replace cover.
  • To adjust the heat anticipator, please see Heat Anticipator Adjustment.
  • Furnace Turns On and Off Frequently ("short cycling")Possible Causes
  • Dirty thermostat components
  • Heat anticipator not set correctly.
Possible Repairs
Sep 30, 2012 | Honeywell Programmable Thermostat Heater
The furnace cuts on and off frequentle so I am trying to adjust the anticipator, but i dont know where to move it
Try moving the anticipator to .2 or .3 There is a right way to do this but I need to keep it simple for you. Try.2 first. If it still short cycling move to .3. A 5 degree differencial is needed. That means if you set the thermostat at 70 then it will come on at 67.5 and off at 72.5. this keeps it from short cy.
Jan 14, 2011 | Heating & Cooling
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? (i am in Australia.) Thank you in anticipation.
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? Philippines Thank you in anticipation.
Jul 12, 2010 | Vacuums
Brew temperature is too low
I think you ment kaffeestudio.de and their webshop redirects to
http://www.juraprofi.de/Service-Anleitungen:_:70.html
Eg http://www.juraprofi.de/anleitungen/E-Serie_Innen.pdf
May 31, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Honeywell RTH2310 thermostat temp variance
Yes you can change that by change the number of cycles per hour that your t-stat looks from for youe furnace. Lower the cycles per hour number and it will increase the range.
You can see how to do it here
http://dl.owneriq.net/3/39359643-dfda-451d-bb81-828eecddd9fc.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
170 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
