Question about Jenn-Air JSD2789GEW Side by Side Refrigerator
Jenn Air JSD2789GEW side by side Refrigerator not cold
I have adjusted the temperature bar but it doesn't seem to be as cold as it used to.
If the adaptive defrost timer is out (hidden circuit board at top of fridge behind light panel), the freezer coils will ice over & prevent the air from circulating over to the fridge side. If the defroster coil or temp sensor is out (lower freezer side behind large panel), it will cause the same effect. If the "start relay" on the compressor is going bad, it may not allow the compressor to come on when its supposed to. My unit suffered from this. It still cooled, but not nearly as well as it was right after I replaced the adaptive defrost timer. I noticed I heard clicking for around 15 seconds.. this was the relay trying to function & activate the compressor. Perhaps the faulty adaptive defrost timer caused the compressor relay to go bad? Regardless, those are the usual suspects I'd tackle first. They can all be tested to prevent the expense of "part changing" Adaptive defrost timer is ranging from $35-$79 online..your loca maytag/jenn air dealer will have these in stock as they are the most common culprit. Relay is $10.50, defrost heating element around $50. These are all very simple & easy to replace. Pretty much just a philips screwdriver & removing a few panels. Remember, ALWAYS make sure any electrical device is unplugged before servicing, also, some capacitors (i.e.,around compressor) will hold a charge like a battery & will zap you. Always test the wire with a meter before touching. The real expense is having somebody do the work for you. Good luck.
Posted on Jul 18, 2010
Jenn-Air JCD2389G Side by Side Refrigerator Damper Door fell off. How do I put it back and what will happen if I cant?
Not knowing exactly how you broke it off, its hard to say just how its supposed to go back on. Since these are usually screwed into place, or in some cases its a snap tight fit, something is definitely broken, and you will likely need to replace the damper door. If you do not fix this properly, you will not be able to adjust the fresh food temperatures, and in fact you may freeze your refrigerated food, or it may be not cold enough to keep food fresh at all.
Feb 01, 2011 | Jenn-Air JCD2389G Side by Side...
This refrigerator leaks. Is there a pan or something that should be catching it? The leaking over time is causing damage to my floors. HELP
check the drain if there is water dripping on it if not try to uncheck the piping for drain if there is clog
Sep 07, 2010 | Jenn-Air JSD2789GEW Side by Side...
Can't change temperature
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
May 24, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Smelly Jenn-Air Refrigerator
some of the most elusive odors can be developed by a rotted piece of fruit,hidden behind drawers,or stowed away inside door shelving somewhere...to remove odors/take about 5-6 charcoal briquettes and wrap them in newspaper this will absorb odor,and yeah-it actually works leave them in for about 2 days
Mar 10, 2010 | Jenn-Air JSD2789GEW Side by Side...
Vegetable drawer freezes items
Adjust your thermostat / temperature setting to a warmer temperature.
You could also have a lot of food placed in front of the vent in the top of the refrigerator compartment. Tall jugs (like milk jugs) are usual culprits of this one. Cold air is deflected in other direction, it might be going straight to the crisper rather than diffusing first.
Jan 04, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2289AT side by side
air damper closed? try to open it by hand.
Sep 27, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air Side by side. The freezer compartment ices up and the refrig does not get cold.
the switch in the back of the ref. needs to be replaced it just happened to ours
Sep 17, 2008 | Jenn-Air JSD2789GEW Side by Side...
Freg side not getting cold
if you do not feel any air coming out there is probably something wrong with the circulating fan or fan blade broken,this can usually be checked by closing the doors or depressing the light buttons on both doors,you should hear the fan or feel flow,when you defrosted did you feel anything upon restarting?if so it could be a defrost problem
Aug 13, 2008 | Jenn-Air JSD2789GEW Side by Side...
Refrigerator freezes things the freezer works fine:
Most common is a dirty condenser coil. If you have not cleaned it recently vacuum and brush the coil underneath and the back bottom compressor compartment. Blocked air flow will cause erratic temps in the refrigerator section.
Jul 28, 2008 | Jenn-Air JSD2789GES Side by Side...
Jenn-Air "replace filter" light
each dispensor is a little different, but youll need to hold down a button(perhaps even a combonation of 2) for3 seconds to "reset " the filter indicator.
Mar 19, 2008 | Jenn-Air JSD2789GEW Side by Side...
Jenn-Air JSD2789GEW Side by Side Refrigerator Logo
147 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
