Switch for heater model #23E02 dors not work,
Switch for heater model #23E02 dos not work, therefore no heat, canyou help?its a charmglow fireplace unit
5 Suggested Answers
SOURCE: Charmglow Electric Fireplace ***NO HEAT** just lights up, HELP :(
http://www.racelectricfireplace.com/docs/Insert_Instruction_Manual.pdf
This is manufactured by Home Depot The customer service number is on the back 800-890-4076.
Posted on Jan 24, 2009
  • 193 Answers
SOURCE: Charmglow fireplace, everything on, no heat
its either a sensor or the element most times sensor or limit.
Posted on Jan 25, 2010
  • 4736 Answers
SOURCE: the fireplace blower does not
This is a constant problem for ALL electric fireplaces with heaters. Either the Owners Manual fails to the manufacturer not telling you that the heating elements need routine cleaning, because they are sucking in household air to heat it and send it back out, So whatever is float in your household air (dust, lint & pet hair) near the floor goes into it, clogs it up and causes the heating element to overheat and fail. Or customers who have purchased these units don't read the Owners Manual.
These units, no matter who the manufacturer is were not designed to heat for long periods of time. In fact the heater element doesn't produce much more heat that a blow drier on high heat.
The heater and the blower and are in the lower compartment of the firebox. If you can access it, you can clean it with a shop vac and a brush attachment on the end of the hose. Be sure to unplug the fireplace from the wall outlet before attempting this. If cleaning it doesn't help, the blower motor will have to be replaced. You can order one from Dimplex USA.
Posted on Feb 06, 2011
  • 4736 Answers
SOURCE: The switch that turns on
I'm sorry, but we don't sell any parts or appliances here on FixYa. We simply provide information on how troubleshoot and/or repair many things. With that said, I can tell you, from what you described, you need more than just and ON/OFF Switch, if in fact, it "burned out". Something else electrically is wrong with your electric fireplace-heater to cause that.
Unfortunately, you failed to mention the Model Number of your Charm Glow Fireplace, so I can't steer you, to where you may be able to find a replacement switch. If you can provide that information, I may be able to help you.
Posted on May 07, 2011
I need to get a manual for a Charmglow electric fireplace Model # CGN250TED-C 25,000 BTU Pure Comfort solutions and I cant find a website, i need to know where to change it from natural gas to propane. ...
I am almost totally confused. You started out saying you have a Charmglow Electric Fireplace. Then you said you want to change it from natural gas to propane.
Could you please be a little more specific in what you have? So I can help you. As Charmglow only makes Electric Fireplaces. No gas ones.
Thanks, I look forward to hearing from you.
Aug 10, 2011 | Williams 2509612 Ceramic Mid-Size Heater
The switch that turns on the heat in my twin star charmglow fireplace burned out, is there a replacement switch that you sell?
May 07, 2011 | Leisure HOMEPRIDE Electric Fireplace...
I have a Charmglow ventless gas heater after it reaches temp, the pilot light goes out.
I have had a Charmglow for about five years and was doing the same thing. I called a plumber that worked with gas fireplaces and he came out, clean the pilot light and now it works great. Cost was $99.00
Jan 09, 2011 | Heating & Cooling
Jan 25, 2010 | Heating & Cooling
Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Jan 07, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Charmglow electric fireplace bad remote control
Here is the home site for Charmglow - you could try to call them and see what they say. I would hope they want to keep their customers:
Charmglow Products 3701 Charlotte St, Pittsburgh, PA 15201-3201 (412) 683-6434 .aBtnGetDir { display:inline-block; width:107px; height:22px; text-decoration:none; vertical-align:bottom; cursor:pointer; } .aBtnGetDirLeft { float:left; height:22px; width:92px; overflow:hidden; font-size:0.85em; background:transparent url('http://sp.ask.com/sh/i/a11/shared_sprite_06.png') no-repeat -99px -401px; color:white; font-weight:bold; text-align:right; vertical-align:middle; line-height:22px; } .aBtnGetDirRight { float:left; height:22px; width:15px; overflow:hidden; background:transparent url('http://sp.ask.com/sh/i/a11/shared_sprite_06.png') no-repeat -301px -401px; }
Dec 12, 2009 | Kitchen Appliances - Others
Charmglow electric fireplace flame does not flicker. Bulbs ok. HEF33WDG
You will have to connect a 12v dc power supply to the flame motor. The controller on the board has fried. I built a regulated 12 v dc power supply and tapped it into the bulb circuit so it will power the motor when the bulbs come on. You may have to find an electrician or techie to rig this up safely.Good luck!
Oct 12, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Take the fan power switch apart and clean the 2 point contacts. Also clean the 4 male studs that the wires plug into. That should solve the problem.
Dec 24, 2008 | Heating & Cooling
Heating & Cooling Logo
168 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
