Question about Pool & Spa
Just installed a used hot tub that was sitting unused for 2 years. Dedicated circuit (120v, 15a, GFCI). All I hear is a click, hum, click, over and over. Any thoughts on whether this is normal behavior or if something is wrong/frozen/etc?
Check for a silver and black lable and check the voltage most tubs due to the high power usage from heating, pumping, lights and filtering are 220 volts and 40 to 50 amps.
Posted on Apr 18, 2013
    President:
  • 1,378 Answers
Check that the pump isn't siezed up.
Posted on Oct 01, 2009
Pacifica Marquis Hot tub serial/model number TH-Y105113 power cord from wall to hot tub
Hopefully you've found your cord by now if not let me know and i'll point you in the right direction.
Sep 30, 2013 | Pool & Spa
Dedicated 20 amp outlet
Ideally you should run the line straight from the circuit breaker out to your hot tub, but if the line running from your circuit breaker to the box you're using now is 20amp. you can absolutely connected to that. to be up to code it cannot be an open box it needs to be closed After you wire in your 70ft connection. (that's assuming the box that you're using is dedicated already to your hot tub) then the only difference would be is your using extra line and costing you tenths of a penny extra and electricity per hour.
Jul 27, 2013 | Electrical Supplies
Are the timers on the Hessco tub and spa hooked up as 220 or 110
Is this a spring-wound timer?
You rotate the timer knob, and it begins ticking?
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
http://waterheatertimer.org/images/Woods-spring-wound-277.jpg
This type mechanical timer will work with any voltage.
What voltage line do you have?
240Volt has 2 hot wires. Connect 1 hot wire to timer. Timer turns off 1 hot wires, and that action will turn off 240V circuit.
120V has 1 hot wire. Connect this hot wire to timer, and it will turn off 120V circuit.
Be sure you have GFCI breaker or Arc fault breaker on spa circuit.
http://waterheatertimer.org/How-to-wire-Arc-Fault-breaker.html
http://waterheatertimer.org/How-to-wire-GFCI.html#2-pole-gfci
Add a comment with more information for best possible answer
Apr 26, 2013 | Pool & Spa
Qo260gfi not tripping
Question is not fully clear.
2-pole 240Volt gfci circuit breaker requires the white wire be connected to neutral busbar.
Easy solution for 240Volt spa that comes with gfci:
Replace spa gfci with regular non-gfci breaker.
Install 2-pole GFCI breaker in main panel, and connect wire to spa breaker.
Having 2 breakers is not a problem.
Having 2 GFCI on same circuit is a problem.
Apr 18, 2013 | Pool & Spa
40 amp gfi on hot tub keeps tripping.I have a 50 amp.can I use?
Your hot tub needs GFI protection because it is electrical, and people sit inside water that could be exposed to electric current.
You have a fault to ground that needs to be fixed.
Size 8 wire for 50Amp breaker.
Size 6 if tub is 50-100' feet away
http://waterheatertimer.org/Color-codewire.html
Nov 09, 2010 | Spa Parts Plus GFCI, Circuit Breaker, 40...
GFCI on refrigerator circuit cuts off.
Yes. Refrigerators should not be on gfci protected circuits. They should have a dedicated 120v circuit .If your kitchen is new enough to be wired with gfci breakers ,it should also have an outlet dedicated for the refrigerator.
Dec 05, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
I just picked up a hot tub and i need to know how to wire it for 110.
First you need a supply or a home run to your panel, or you can tie on to another circuit. With hot tubs you should ALWAYS use a GFCI (ground fault circuit interrupter) breaker or device or you could die from electrical shock (water and electricity don't mix!!!!!!) if its a hot tub its not likely that its 120v because of the heating elements and pump usually they are 220-240v make sure you are using the right voltage or you could burn up any controls and your wasting money. Make sure there is a good ground, GFCI devices need a ground to work properly. Other than that, black or other dark colors are hot, white and gray are neutral, green is always ground. Get yourself a tester and find the hot lead it should read 120v to ground or neutral. Be very careful with wiring its not always done correctly you have to check with a tester. With 220-240v you have two hots, a ground,and no neutral unless the appliance specifically calls for it. this can be very dangerous and if you don't have any experience you should probably call a professional. GOOD LUCK
Oct 30, 2009 | Electronics - Others
1995 blue falls hot tub(arctic spas)
You can go to arcticspas.com but from what I see they are all 230V 50 AMP GFCI breaker requirements. Which means that you will have to have dedicated 240V circuit with GFCI protection as it is a wtaer based appliance. If you have anymore questions please ask.
Thx
Deathstalker
Aug 31, 2009 | Home
Hooking up a Hot tub
Everything above tells me this is 120V unit...if thats the case a single pole breaker is sufficient. Also by what you have written, a 15 amp breaker should suffice.
Jun 22, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
30 amp 2 pole GE GFCI breaker pops on hot tub after hrs of use
I have seen circuit breakers trip at a lower amperage. It seems that they are weak. Generally circuit breakers run with 80% load with no problem, in your case 24 amps. I would replace the circuit breaker.
Jan 11, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Pool & Spa Logo
70 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
