Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
It leaks from the top ring and I wanted to know how to fix it. Thaks
  • Ace Hardware Master
  • 43,501 Answers
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Posted on Sep 29, 2010
Good day, can you please help, I want to know what can be the problem. Our speed queen heavy duty washing machine leaks water when spining. The water leak is at the top of the outer tub where the clips...
The basics would be make sure it's clean, the outer and inter ring of this area holds and builds up dirt and debris over time, causing a bad seal, also has to spin and be balanced properly or it will leak a little. ...
Feb 26, 2015 | Speed Queen Washing Machines
How to fix fuel leak on lincoln ls
Leaking where exactly & why
Was someone working on it & created that situation?
It can only leak from the top "o"ring or fuel line to
fuel rail or regulator or pressure sensor o-rings
Mar 02, 2013 | Lincoln Cars & Trucks
Water is leaking onto the floor underneath my Whirlpool Cabrio (top-loading).
If its a small intermittent leak from the front left corner its the tub ring, whirlpool has redesigned the tub ring to fix this concern..
Sep 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
May 20, 2010 | Intex Easy Set Pool 15x36
Gas leaks from the gas cap past the rubber o-ring
By MANY accounts,not the best choice.Lots of probs starting,exhaust breaking,and one review with your exact point of the leaking gas cap,but his dealer got it fixed.Tuff call,but I don't think "grease" on the o-ring is a top answer,since the gas will just get rid of it sooner or later.If it's not a big choice to fix,I might try a few wraps of TEFLON TAPE like plumbers use on connections and see if that helps.
Mar 27, 2010 | Garden
Gas pump leak
UNDER THE LIP WHERE THE TOP OF THE PUMP FLANGE IS, THERE IS A SQUARE-CUT O-RING THAT CAN BE MATCHED UP AT THE AUTO PARTS STORE. UNLOCK THE TABS ON THE LOCKING RING AND REMOVE IT. CLEAN THE SURFACE WHERE THE SEAL GOES. REPLACE THE SEAL(O-RING) AND REINSTALL THE LOCKING RING AND CHECK TO MAKE SURE IT IS TIGHT. HOPE THIS HELPS. LET ME KNOW. THANKS FOR USING FIX-YA. AND THANK YOU IN ADVANCE FOR AN HONEST RATING.
May 07, 2009 | 1997 Land Rover Discovery
How do i fix a fuel leak at top of injector on 7.3l 1992 f250?
Either your lines arent pressuring up and its pushing fuel back out the injectors or the o-rings on the injectors are bad. I had the same problem...I replaced the o-rings and it fixed it!
Mar 28, 2009 | 1992 Ford F250
Air leaks from top of nailer
Is this broken o ring about the size of the cylinder? If so that would probably be your air leak. You can go to Stanleybostitch.com and look at a breakdown and also order parts. If youu give me the model number I will help you with numbers. While you are at it how is the piston o ring, does the piston stay where you move it to or fall down without any pressure. If it does you might want to think about all new o rings for the tool. Let me know
Jan 15, 2009 | Stanley Bostitch N86S 1 Factory...
Power steering leaking
Joe Rilla this in Mike Lee. elvisml2@gmail.com or 242-376-1295. Drop me a line.
Sep 03, 2008 | 1990 GMC Safari
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
108 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
