Question about Hilti TE 7-C 120V Rotary Hammer Drill
Have a te6c and the chuck fell off- how to put it back on? looks like may require a large vise to press it on?? phil
  • 2,176 Answers
Pull back on the collar of the chuck and slide it on and then release the collar and turn till it locks onto the spindle.
Posted on Oct 01, 2009
How do you remove the chuck from a 3/8 electric drill
Open up chuck for largest drill bit. Look inside and you will see a screw, remove the screw. Put a pair of vise grips on the stationary part of the drill chuck, which is the part of the chuck that the tightening tool goes into. The chuck is screwed onto left hand threads. Take a rubber mallet and hit the pair of vise grips clockwise sharply, to loosen chuck. You can now do what you planned on doing. GOOD LUCK FRIEND.
Feb 12, 2015 | Drills
Removing chuck
You don't say which drill you have, but this is one method.
Remove the left handed screw from inside the chuck, put the drill into low gear then lay the machine on it's left side, fit a suitable spanner on to the slot behind the chuck and arrange it so that the spanner is against the work surface. Put the chuck key into the chuck and give it a hard blow so you knock it in an anti clockwise direction. If it is a keyless chuck or you don't have a key try holding the short end of a large allen key in the chuck and knock the long end in a anticlockwise direction. This will work even if you don't have a spanner to fit behind the chuck but you might have to hit it harder. If you have a vise after removing the screw hold the chuck in a vice and fit the spanner behind the chuck and turn it anti clockwise.
Jan 03, 2013 | Makita Drills
Hilti TE72; i have a problem getting the bit out of the chuck, the sliding collar will not go back far enough due to damage on the metal shroud it slides over. How do i get the chuck off to get to it,...
First you lock the bit into a vise. Very tight. You then put a pipe wrench on the cap nut. The end piece with the metal ring with the holes in it. It will take a lot of effort to break it loose. It has regular threads. Screw the cap nut offf. oh yeah you can take it out of the vise now. under the cap nut you should have a large o ring. Remove that and the locking sleeve should move foward far enough to uncover the roller bearings holding the bit. You should then be able to remove your bit, the lock sleeve, the spring and the metal bell cap that is bent. Take a large diameter socket and lock it into the vise. but your bent bell around the socket and tap with a hammer until the dents are out. Then reassemble putting axel grease on the roller bearings to hold them in place. Again you will have to put your bit in a vise when it is back together to hold the chuck while you tighten ti down. DO NOT TRY TO TIGHTEN THE CHUCK WITHOUT A BIT IN IT AND LOCKED INTO A VISE. FAILURE TO DO THIS WILL RESULT IN BREAKING THE SHIFT DETENT AND THE HOUSING INTERNALLY.
Hope this helps
May 30, 2011 | Drills
How to change the chuck on 18 volt cordless drills
Set the drill to reverse. Hold the chuck, press the trigger and open the drills chuck to it wide open position. Now,, take the correct size allen wrench and insert it into the back of the chuck to remove the screw. Turn the screw clockwise to remove it. Notice I said clockwise, just the opposite of what you might think. Hold the chuck with your hand or a pair of large vise grips and press the trigger to unscrew the chuck from the drill. Rotate it counterclockwise to remove it from the drill. Reverse the procedure to install the new chuck.
Mar 10, 2011 | Dewalt 18 Volt Compact Drill Kit
How do i replace the jacob chuck on a hilti hammer drill?
Open the jaws of the chuck all the way open. Inside the chuck you will see a slotted screw. Use a large flat head screw driver and remove screw. It will have left handed threads.
After you remove the screw put the end of the chuck in a vise where the 6 flats sides are. Put the drill in low gear and reverse. Hold tight and turn on the drill. This should run the chuck right off the spindle.
Jun 28, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
I have a Black & Decker 18V cordless drill with keyless chuck. The spot where the drill bit fits is in the open position stuck and won't turn in either position. What am I missing how to unlock it?
Look at the three jaws in the chuck,if on is further out than the others the you need to tap ti back into place with a small punch and a hammer.If this does not work then you need to replace the chuck,remove the screw at the bottom of the chuck[where you put the bit],then you will need to to clamp vise grip on the chuck and with it pointed away from you hit the vise grips with a hammer with a sharp blow downward and it should come off.Hope this helps.
Jun 12, 2010 | Black & Decker CD9602SB 9.6 Volt Cordless...
Would like to replace the 3/4 Chuck on Jet Drill Press
Grizzly sells a nice variety of quality chucks at good prices. Look at the numbers on the chuck you have to determine what to buy. You should remove and re-use the taper from your present chuck. You probably have a Morse #2 taper up into the spindle like the picture shown below. I assume you know 92bb256.jpghow to get that out of the spindle. What is not shown in this picture is the taper that is inserted into the chuck. This is probably a Jacobs taper. To separate that you need to support the chuck in a vise with the long taper pointing down. Put something below it to catch it without damage when it falls out. Open the chuck as far as it will go. Get a bolt (about 3/8) that you can hit with a hammer inside the chuck straight down to knock the taper out of the back of the chuck.
Apr 12, 2010 | Jet 354170/JDP - 20MF 1 Drilling Capacit...
Cannot remove drill bit from self locking chock
If you are having trouble turning the chuck to remove the drill bit just wrap a cloth around it a couple of times and use a pair of adjustable channel lock pliers to give yourself a mechanical advantage. If you have loosened the chuck but can't remove the bit just clamp onto the bit with a pair of vise grips and tap them a few times with a hammer while a friend holds the drill for you.
Nov 09, 2009 | Drills
Chuck jaws on Makita 8444D fell out
There is suppose to be a flat head Left hand thread chuck screw in there. It may have fallen out. You will not be able to put the jaws back into the chuck. You will have to replace the chuck with a new one. If you make sure that the chuck screw is not there you can remove the chuck with a couple of steps. Make sure the drill is in it's lowest gear. Use a strap wrench or some large vise grips on the chuck. If there is still one jaw in the chuck make sure it is all the way open and locking the collar to the chuck. The chuck will come off in the regular lefty loosey configuration. It may be stubborn. If this is the case, You may have to cut the collar off the chuck and use a pipe wrench. Or bring it to a professional to get it changed out.
Sep 23, 2009 | Makita 18 Volt Cordless Hammer Drill Kit ...
Remove chuck from a dewalt dw953
I work in a large shop and I do most of the tool repair.  We do use DeWalt cordless guns so I have done this before.   I change these as often as they break at work.  About every 4 months the teeth fall out of a chuck and I replace the chuck with a new one.       To remove this chuck you should  use a heavy duty metric allen key and a good vise. The trick is to remove the small metric reverse thread screw. It is between 3 and 5mm.  Place the "L" of the allen key firmly in the vise with the long end pointing straight up.  Open the chuck all the way. Using a fully charged battery, place the gun in low (1st gear) and put the direction of the gun in FWD (as if you were driving a screw in), set the clutch to the drill setting (maximum torque) and drive that screw out of the chuck.  If the battery is not strong enough to drive the reverse thread screw out you will have to help it out.  Rotate the rear of the chuck clockwise and hopefully the screw will come out.  If that is not enough torque, I find the use of a small strap clamp helpful to turn the chuck against the reverse screw. Hope this helps.  Best Results!  Michael Mittelsdorf
Jan 05, 2009 | Drills
Hilti TE 7-C 120V Rotary Hammer Drill Logo
162 people viewed this question
Top Hilti Drills Experts
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
