Question about HP Vs17 17" LCD Flat Panel Monitor
No sound, buttons on side of monitor when pushed says "OSD locked"
    Problem Solver:
  • 9 Answers
Hold the menu button for at least 10 seconds to unlock OSD.
Posted on Oct 01, 2009
How to unlock osd lock lg flatron w1643c
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear. system admin
May 30, 2012 | LG Computers & Internet
How do I unlock the OSD?
Unlocking the OSD menu
  1. Turn the monitor off.
  2. Press and hold the Menu button.
  3. Press and release the Power button.
  4. Release the Menu button.The OSD is now unlocked.
Apr 26, 2012 | LG Computers & Internet
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
OSD locked. Can't get mouse to work on monitor
-Press and hold the MENU button (on the monitor) for several seconds.
-The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear
Nov 24, 2010 | LG Computers & Internet
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
plz do rate the solution if helped
Nov 22, 2010 | HP L1506 15" LCD Monitor
The button on the front has functions but when I press either the left hand side or the right hand side it just comes up with a message ''OSD Locked'' What does this mean
OSD Locked means that your On Screen Display is locked. That basically means you can't access/change the menu settings. The way to unlock the OSD varies from manufacturer to manufacturer and even monitor to monitor. Here are a couple different ways to unlock it:
1) The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
OR
2) Go to Menu and select OSD settings and change the setting for the OSD Lock. For example if it is a "+" then make it a "-" or a "On", then make it an "Off", or an "Enable" then make it a "Disable".
If neither of these work, I would contact customer support for your monitor from the manufacturer. They should be able to tell you how to turn off the OSD Lock.
Hope that helps. Good luck!
Feb 15, 2010 | Computers & Internet
W2361VG Monitor "OSD Locked" and service menu
This just means the On Screen Display (OSD) is locked. Press and hold the menu button on the front panel for 10 seconds.
Aug 29, 2009 | LG L1915S 19" LCD Monitor
W2361vg
Osd main controls locked
that depends on the brand and model of monitor ,
it normally takes 2 buttons pushed at same time to unlock it.
if you have side buttons its normally them.
May 12, 2008 | Gateway FPD2275W LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
106 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
