Question about Xerox 8830 Copier
I have a Xerox 8830, that is getting a LL43 error
Haven't used this plotter in a a while. Tried to print a doc and got LL43 error. Is there a quick fix? turning the plotter off and on again didn't work.
An LL43 is a fuser temperature error.
When you first turn on the printer it should display printer warming up and after a little while display the LL43. If the fuser is still cold then you probably blew the thermal fuse and it will need to be replaced.
Posted on Dec 23, 2009
8830 Idle Message
Try to reinstall the driver. You can get the latest from the link below:
http://www.nodevice.com/driver/xerox-8830-printer/get126620.html
Sep 23, 2013 | Xerox Office Equipment & Supplies
Line appears on copies from top to bottom of the sheet, Approx 7 7/8 in. It happen both off the glass and when ripping a job to machine
With lines showing up with both coping & printing, you are most likely need a general cleaning and if that will not work, odds are you are going to need a new OPC drum & drum cleaning blade and a new developer change..... Good Luck
Nov 09, 2012 | Xerox 8830 AccXES N5T Wide Format Digital...
Xerox 8830 LL43 ERROR. I see it is a thermal fuse error. do I have to replace the fuse or can I get the machine running again. Thanks,
Open up the Printer and lift the optics bar up and back to expose the drum.
Unclip the drum on both sides and slide back the drum ( CAREFULLY ).
Pull up and back on the drum and let it lock into the upright position.
Under all this is several rollers and whatnot. There will usually be a big pile of toner/media collected under them. Vaccum them out being careful of the drum in the process.
You will also see the bar along the back with Toner/Media magneticly stuck to it.
Leave the toner there. But at the edges of this bar is usually something to prevent electricity from passing through it. Foam tape usually. If it is worn through. Put some tape over these spots. and directly below them on the flat metal surface. Not much tape just enough to cover those little areas.
What happens is when these spots are worn off it allows electricty to flow through it bypassing the fuser. If this happens the Toner/Media will not " Stick to the print " and will fall bellow. enough of this happening will cause all kinds of error messages. Clean it out like this and save your self $$$.
Aug 11, 2011 | Xerox 8830 Copier
I have LL43 on dispaly
If this does not work place a service call.
Power printer on and off. Make sure you power OFF the printer before powering OFF the Controller, and power ON the printer before you power ON the Controller.
  1. Power OFF the printer. The power switch is located directly to the left of where the power cable enters the machine.
  2. If you have a Controller installed, power OFF the Controller. Not all printers are equipped with a Controller. The Controller power switch is located just above the power switch.
  3. Wait at least 10 seconds.
    NOTE: Powering OFF, and then ON again too quickly will result in a software error.
  4. Power ON the printer.
  5. Power ON the Controller.
  6. Switch the A / B button to the ON position. The button will be in the out position and the green light will be ON.
    NOTE: Not all machines have the A / B Switch installed.
Mar 16, 2011 | Xerox 8830 Copier
Drivers for copier and scanner xerox 8830
Hi
You can download 8830 drivers from http://www.xerox.com/digital-printing/large-format-printers/enus.html
you need to check the type of controller that is fitted to printer.
Look on the back at box where connections are terminated.
label should have (F5Y or CNG - N5T - HFT and others select which is fitted and operating system, other support documents are also found here.
Jan 24, 2011 | Xerox 8830 Copier
My plotter isn't giving me a preview of my documents that I have scanned
u have to press the sample button on scanner before scanning the document
Apr 30, 2010 | Xerox 8830 Copier
When I send to print some file not printing, the plotter indiquet procesing and not printig ,plotter can scan, No. IP is correct, Submasc is correct, the conection is correct
before you print go to the page setup and din adjust the bottom or gutter and try to print preview and look carefully the area you want to print if completely present or try to uninstall the microsoftword and install again
regards
fdlixboy
Jul 08, 2009 | Xerox 8830 Copier
I have a Xerox 8830, that is getting a LL90 error after printing a couple jobs. I can restart and the error will clear but than comes back after a couple jobs. Is this a sensor or is it some other problem?
LL-90 and LL-91 refer to low toner and too much toner. If low, the cartridge is nearly empty, if too much, tape off half the holes on the cartridge.
Jun 15, 2009 | Xerox 8830 Copier
506 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
