Question about Sony Televison & Video
Need to retune my sony digital receiver model vtx d800u cant retune need factory reset pin number
SONY VTX D800(U)
Full Reset (Also clears Pin)
LEFT
RIGHT
YELLOW
BLUE
MENU
Go to Technical Information
Go to Manufacturer Information
Press Red
Posted on Oct 10, 2009
  • NIGEL BLACKBURN Jan 11, 2013
    This got me back to the unlocked mode. I managed to guess the old pin number. It didn't enable me to override the pin required phase but has solved my probelm thank you very much.
After retuning lost access to record / playback on menue and a games button has appeared instead. Have tried turn off/onn and revert back to factory on numerous times without success
Also be sure to include your model number when asking questions, it helps a lot. Always try to check your owners manual to see if there is a reset to factory button or series of buttons to reset device.
Sep 01, 2015 | Televison & Video
How can I fix a tv that has been reset to factory reset
Try resetting it again, resetting it should bring it back to the way you received it from the store. Unplug it first, then plug it back in, then try the factory reset.
Jun 08, 2014 | Audio Players & Recorders
Accidentally set my TV to factory defaults
only digital signal is available now analog has been switched off no longer transmitting. You could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure . retune the digital channels only
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
Jun 04, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KDL-32NX503 I have no channels 1-9 after retuning.
Do a factory reset to this set. Refer its user manual for details.
Apr 22, 2012 | Sony Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
Ldc tv with built in freeview wont tune to bbc 1 bbc 2, retuned 20 times still no bbc 1 bbc 2 . before i did retune i would receive bbc wales post code OL16 2RR North west
Buy a digital antena,or roof antena recieve better siginal,get everythings.Tries reset to factory setting retune again will get BBC1,BCC2 well get it back.
Dec 18, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Forgotten reset code.need it to retune
most factory reset codes are 1234 / 0000 / 5555 or 8888
Dec 15, 2009 | Televison & Video
How do i retune Sony Bravia KDL-20S2030 "settings" does not appear to include retune
Go to the following site link, insert your model details and following the instructions carefully for your model. I did this and it worked OK for my Bravia
http://tvretune.co.uk/productmanuals
Oct 02, 2009 | Sony BRAVIA TDM-NC1 Digital Media Streamer...
Forgoten pin number
I read that there is a factory reset that you can do. This will return the unit to how it was when it came out of the box.
Firstly you have to enable the diagnostic functions by quickly pressing the following sequence on the remote:
Left
Right
Yellow
Blue
Menu
Then on the Technical Information pages there will be a reset option. This clears everything - channels, favourites, PIN etc.
There will be a default PIN that comes pre-programmed in and the instructions should mention this.
Oct 01, 2009 | Audio Players & Recorders
Lost bbc1 on digital only. retune and factory rest fail to fix problem. bbc1 received by another digibox on same aerial.
Try retuning again and then look at the EPG as it may be allocated to a different number than you are used to. If so then you will need to edit your channel list.
Aug 13, 2009 | Panasonic TX-32LXD1 32 in. LCD Television
Televison & Video Logo
749 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
