Question about HTC Touch Pro Smartphone
The touch screen stop working is there any way to send a text without having to click on the send button on the touch screen?
My touch screen quit responding. I can unlock it only to reveal the inbox display. It will not do anything else.
sorry. its junked. i'm on my second env touch and its doing the same thing. the first one would start randomly sending blank reply texts to whoever was at the bottom of the text history. the only way to stop it was to open the phone and delete the history... then it would just click constantly. i was replaced with a "refurb" phone. worked great... till yesterday. now its starting the same thing. the "unlock slide" hangs about 1/3 of the way up.
hold the phone up.if you see a dark variable line and/or small dark circles in the otherwise silvery reflection on your touch screen, its bad. there really isnt much of a fix that i'm aware of, other than replacing it.
Jan 18, 2011 | LG enV Touch VX11000 Cell Phone
My chocolate touch just stopped working. The touch screen will not work at all. The buttons work but the screen just quit working. It is very frusterating because I can't look at lexts, send text, call...
Remove the covers and doa cleaning , use a hair dryer to take off any moisture that would have condensed or a possible sweat accumulation.
Make sure that the touch pads leads to the boards are clean and intact. the membrane leads must be checked for good contacts.
reset the battery, and test. If the set boots up well then it is possible that the touch pad is faulty.
Dec 09, 2010 | Cell Phones
My Blackberry curve 8310 constantly reboots when I'm in the middle of a text, a phone call, or when it's just sitting on my desk. It happens several times a day. It seems to happen less often if I...
This issue only occurs when trying to send a SMS text message from within the call details screen of a call in the call log.
To avoid this issue, complete the following steps to send a SMS text message from the call log screen:
  1. Open the Phone application.
  2. Open the Call Log by clicking the middle button in the toolbar.
  3. Touch the call log/contact in the list without clicking the screen.
  4. Display the menu, then select SMS Text (Name/Number).
  5. If required, rotate the BlackBerry smartphone to switch to landscape mode.
Oct 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
White screen
Oct 27, 2009 | RIM BlackBerry Pearl 8100
How to send a text message on a htc touch pro shattered screen
there is no way out other than getting your display corrected..
Jul 26, 2009 | HTC Touch Pro Smartphone
Xenon Touchscreen stopped working
There is no way. My touchscreen has stopped working several times and everytime fixes itself after a few hours. DO NOT let this phone ANYWHERE near moisture or water, the touch screen is very sensitive.
Jul 17, 2009 | LG Xenon GR500 Cell Phone
My touch screen is unresponsive [LG glimmer]
I have this all the time: 1. Inbox/ sent msgs are 2 full - so delete msgs 2. remove the battery out & clean sim card 3. If that doesnt work get a new simcard 4. if else fails- get a new phone
Jul 13, 2009 | HTC Touch Cellular Phone
Texting issues
How can I send a Picture in a text message with the HTC Touch Phone
Jul 15, 2008 | HTC Touch P3450 Smartphone
Touch Screen 'Back' button on my K850i affected by every other button.
problem solved. i had the same problem but i fixed it somehow. one day i just took a iron thick pin and pressed the space between number 5 and left-down button(not in the gap). and then i pressed between left-down key. Instantly it started working fine. i dont know whether it was my luck or i just accidently found a solution.756425f.jpg
Jan 23, 2008 | Sony Ericsson W850i Cellular Phone
HTC Touch Pro Smartphone Logo
145 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
