Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have kingston 2gb usb pen drive. i tried to copy some media files to it.but it is not being done. what shall i do?please tell me a solution
  • 3,153 Answers
Check Item 6 in the list below
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 01, 2009
  • 44 Answers
Chk if you hav enough memory space on your disk.. If you have sufficient memory space and still the drive isnt working well, try to copy the data to a safe location, format your drive, reload your data(be sure to check them witha good antivirus ) and execute your instructions...
Pen drives are prone to virus attacks due to easy and open access features..also rough handling(removing device physically without safety removal feature) often destroy the file formats.
Formatting will surely help.
Hii sir pls help me mine kingstone data traveler 2gb is write protected so how shall i remove write protected?
Copy all the files onto your 'C:' drive.
Spend $9 to buy a new 2GB USB memory-stick.
Copy the files to the new memory-stick.
Take a sledge-hammer to the old memory-stick -- to prevent anybody else from reading your files.
Oct 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
32 Gb Kingston pen not working
Format the pen drive first, then copy the files.
Nov 16, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have kingston 2 gb usb drive. i tried to copy some media files to it. but it is not being done.Please tell me a solution
scan with mcafee 8.5i enterprise ver antivirus......problem is due to virus in pen drive or in your system....
Oct 01, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Problem with 32 GB kingston pendrive
i hv a 32 GB kingston pendrive, it can copy any type of data but whenever i copy from pen drive into my pc or copy from my pc to pen drive, it shows multiple empty folders in the same folder n audio-video files got currupted, softwares too. and also unable to delet
May 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Cant open cant formate my flash
hmmm....hello friends...your pen drive is corrupted...its better to change this pen drive because kingston pen drive is in 5 yr warrenty period... so dont wrry and change it.....or you can try this pen drive to any other computer ...if behaviour is same then i would request to you , change pendrive as soon as possible
Apr 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Not able to copy more than 1GB into 2GB Kingston SD card
Hi 1123sun,
Copy your files off the card. Then Format the card and select FAT32 file system. After the format is done try the card again and see if you can copy more files to it.
Kingston Tech Support
Feb 18, 2009 | Kingston 2GB Secure Digital Memory Card
My 1gb kingston pen drive is write protected
Try to right click your pen drive then copy and paste it on your My Documents folder. When done, follow these steps:
1. Go to start menu
2. Click Run and type cmd
==A command prompt shows.==
3. Type cd\
4. Type format x:
5. Press Enter key
6. When done type exit
Note: Copy all the files you have transferred on your My Documents folder and paste files again to your pen drive. You can now do whatever you want on your pen drive.
Dec 25, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston 32gb pendrive
I have a 32 Gb pen drive of Kingston
I copy the files or folders then it is copy but some foldres or files are not run there . so I have formatted my drive many times but the result is same, why it happen so please some one suggest me to solve this problem.
Dec 17, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Wen i copy files or data, few gets copied and the rest doesn't.
Hi rijo_frendz,
Format the USB drive. Then create a folder on it and copy your files into the folder. It should be working now.
Dec 09, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
Top Kingston Computers & Internet Experts
Cleverer2
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
