Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I have a bizhub 750 that I cant keep the scanner from comming out of adjustment. It shifts down and away from the leading edge
  • 44 Answers
Did you try it from the platen glass? make sure it's the just the ADF and not the optics. Try it from different trays.
Posted on Sep 04, 2010
C3803 code trobleshot
Sir/Mam, turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it see a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 27, 2015 | Konica Minolta Bizhub 600 750 Image...
Why does our bizhub c220 make a clicking sound all the time?
Sounds like the fuser unit is starting to reach the end of its life.
Sep 01, 2014 | Konica Minolta Bizhub C220 Color...
C-6708 code
Does your exposure lamp come on ? Mite have a problem with the scanner lamp or the Scanner reader that the CCD the black device under the big glass that views the document to be copied. Exposure lamp is what high lights the original document(s)
May 30, 2014 | Konica Minolta Developer 02xk Dv710 for...
How can i dix error c1101 on bizhub 750?
Finisher related error code. The shift unit that slides the paper to create the offset sorting does not shift in the correct time. Possible causes would be foreign material blocking shift gates, mechanical failure of drive motor, failure of home position sensor, and failure of controling board.
Apr 29, 2014 | Office Equipment & Supplies
How do l adjust ATDC gain on bizhub 500
You cannot manually adjust the ATDC gain in bizhub 500. Replace the developer and execute TCR sensor adjustment in service mode.
Mar 19, 2014 | Konica Minolta Bizhub 500...
Konica minolta bizhub c450 error code 6102
C 6102 Drive system home sensor malfunction.
Correct or change the scanner drive cable,pulley,gear,belt if it is faulty.Correct the scanner motor set screw if loose.Adjust image position leading edge and feed direction adjustment.Check the scanner home sensor,scanner motor and the connectors.
Mar 30, 2013 | Office Equipment & Supplies
2002 Kawasaki VN 750 Vulcan will not shift
Hi, Jose and the usual suspects are:
1. Improper clutch adjustment or not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
11. Shift lever loose on the shift shaft.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Floppy gear selector wont go in any gear video Kawasaki Vulcan 750 Forum...
Shifting problems Kawasaki Vulcan Forum Vulcan Forums
Kawasaki VN 750 Service Manual
OEM Parts for Kawasaki
2002 Kawasaki Vulcan 750 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 12, 2012 | 2002 kawasaki VN 750 Vulcan
1988 Kawasaki VN 750 Vulcan will not shift
Hi, Anonymous and the usual suspects are:
http://www.vn750.com/forum/26-transmission-rear-end/1601-shifter-not-working.html
Shifting problems Kawasaki Vulcan Forum Vulcan Forums Kawasaki VN 750 Service Manual
1989 Kawasaki Vulcan 750 Owner Manual
Mar 29, 2012 | 1988 kawasaki VN 750 Vulcan
1986 Kawasaki VN 750 Vulcan hard to shift into 2nd gear
Hi, D1602 and the usual suspects are:
1. Clutch not adjusted properly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. A loose shift lever on shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
Shifting Gears Kawasaki Vulcan 750 Forum Kawasaki VN750 Forums
http://www.kawasakimotorcycle.org/forum/mechanics-corner/128592-2004-vulcan-750-cant-shift-into-2nd-gear.html
May 01, 2011 | 1987 kawasaki VN 750 Vulcan
1994 Kawasaki VN750 Vulcan, transmission won't shift
Hi, Rock_johnson and the usual suspects are:
Bike not shifting Kawasaki Vulcan 750 Forum Kawasaki VN750 Forums
http://www.kawasakimotorcycle.org/forum/mechanics-corner/128592-2004-vulcan-750-cant-shift-into-2nd-gear.html Kawasaki VN 750 Service Manual
1994 Kawasaki Vulcan 750 Owner Manual
May 13, 2010 | 1994 kawasaki VN 750 Vulcan
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
100 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
