Question about Whirlpool Duet GHW9150P Front Load Washer
It is a model # WFW8300SW01 During a cyle it stops and error message F-11 appears.
    President:
  • 1,776 Answers
This code indicates a serial communication error, meaning communication between the central control unit (ccu) and the motor control unit (mcu) cannot be sent correctly. Check the wiring harness connections at the CCU and the MCU. Unplug and reseat and make sure there is no corrosion. It can also indicate a problem with the door lock relay on the control board, a faulty hall sensor, or the mcu or ccu themselves. I think that I'd recommend getting an appliance tech to take a look at it, but try the unplug/reseat electrical connections fix first. Very sorry for your trouble. Hope this helped and best wishes.
Posted on Oct 01, 2009
Eh0 error message during operation
need manual or need to know if washer starts and when it stops as this can identifie the problem
Aug 12, 2012 | Zanussi Washing Machines
The washer stopped in the middle of a wash cycle. The error message was 11 F. I turned it off and turned it back on and washer stilled stopped and repeated the error message.
Hi
An "F-11" error code on a Whirlpool Duet could cause your washer to become inoperable and stop in the middle of a load. The cause of the problem could be a number of things and may require new parts.
F11 can mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor.
Identification
The "F-11" code could appear with the dash or without the dash on the LCD screen. Be aware that there is also an "F-H" code that could look similar to the "F-11" code. Listen for 11 beeps to go along with the error code's first appearance.
Effects
The error means that there is no communication between the "Motor Control Unit" and the "Central Control Unit." This means that any operation selected like "Pre-wash" or "Large Load" cannot be sent to the motor for the washer to operate.
Prevention/Solution
Open up the washer panel to check the wire connections between the two units. If any plugs are loose or unplugged, reconnect them. Check to make sure none of the wires are stripped, rusty or broken off. After you reconnect the wires, rerun the washer to see if the error appears again.
Warning
If you do not know or understand the inside components of your Whirlpool washer, leave the job to a professional. Contact the store where you purchased the washer or Whirlpool customer service directly.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error message appearing "power failure occurred
Push the Start/Stop button on the Neptune to reset the machine.
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Scanner initialization error -scanner does not stop moving to right. eventually stops but will not function.
Error messages might appear during scanning. Click here to see the document which was developed to help HP customers resolve these error messages.
Regards
Riztech
Aug 23, 2010 | HP PSC 2110 Color Printer
Wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Sep 20, 2009 | Washing Machines
SUD message appears
My manual says that Sud means that you are using too much soap. The washer will say this mid cycle until it gets rid of the extra "suds" and should then resume the cycle. If it doesn't, then you have a different problem.
Apr 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Getting Error Message during game play.
There is a guide that you can get that will solve all errors like this and black screens it has been a lifesaver for me. Have a look at http://www.freegamesforwii.info/?cat=11 they have info on where to get this guide. I cant remeber the site off the top of my head,.
Hope this helps
Mar 03, 2009 | Nintendo Video Game Consoles & Games
Message on screen 8E, Motor won't start on spin cycle. Model no Q1435(C/S/V)
This is what I found:
11. OVER CURRENT ERROR - Display shows 8E .
- IPM fault signal (that is caused by the overload of MICOM INT0 during motor action) is sensed.
IPM : Integrated power module. , IPM controls motor.
- If the fault signal (low signal) happens to be sensed even one time during cleansing/rinsing stage,
the motor stops immediately. However, during dehydrating stage the signal is to be sensed
when the number of signal is more than 6 for 500ms.
- During Cleansing or Rinsing
When the overload is sensed, the motor stops immediately and then proceeds to the next water-flow action.
If the stopping of the motor working is happens in one direction ten times,
"8E" Error is displayed.
- During dehydrating
When the overload is sensed, the motor stops to work at once and then feeds back to the initial
stage of the dehydration unbalance sensing.
When the feed back is continuously happened 2 times, "8E" Error is displayed
During the dehydrating unbalance sensing, No error happens by overload sensing.
When it happens at more than 800rpm, the process is stopped compulsorily.
-Power S/W Off can clear the overload error.
in short: imbalance problem
In a german forum one guy solved the problem by replacing the motor electronics. I am currently experiencing the same problem. I keep you posted.
May 08, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
143 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
