Question about Garden
Ppressure washer doesn't seem to be delivery full volume of weater. Making a noise a bit like a dog sort of growling.
ButtFuzz
  • 463 Answers
SOURCE: noise from the rear of my 97 crv when turning left and right
Does the noise have any sort of metallic sound to it? I had a '97 CR-V and when I turned hard right or left it would slighty bind the exhaust sytem. Just enough over time to cause the spot welds on the heat shield over the resonator (the "muffler" behind the catalyst) to fail. When I'd turn sharp, the heat shield would lift slightly due to the failed welds and vibrate against the resonator. Took a bit of head scratching to find this one.
Take care.
Posted on Feb 27, 2009
  • 423 Answers
SOURCE: LG Dishwasher LDF7811 Making Growling Noise
Recommendations:
-Switch to a brand name detergent powder - like Electrosol or Cascade and do not fill the dispenser cup full. You will notice the difference immediately.
-Remove the filter assembly one more time and inspect underneath with a flashlight. Look closely for debris and also inspect the impeller to look for damage and that it is spinning freely.
Reassemble and listen for the growling sound. It should not happen. If it continues, you may have a a failing wash motor / motor bearing.
Please report back what you find. OK?
Posted on Apr 11, 2009
SOURCE: Transmission noise (growl)
It is at least one of your wheel bearings. I had all four of mine replaced before 40000 miles I hope that it is under warrantee
Posted on Jun 08, 2009
  • 1531 Answers
SOURCE: fridgidare affinity washer will not spin, makes a growling noise
use a shop vac and attach it to the end of the drain hose remove all the water then you need to check the drain pump and see if there is anything blocking the pump.
Posted on Sep 27, 2009
miket756
  • 2702 Answers
SOURCE: Started making lud growling noise
growling noises??? hmmm? well if it starts to bark at you,,, feed it?
this sounds like the old problem,,, its about to pop its socks,,, or drop dead on you,, its clearly an inside job, there is most likely a leek in the capacitor, most comon, realy not worth repearing it, and please dont go getting inside it yourself,,,,you cant fix it,,,but you could easly kill yourself,,, that capacitor holds 1000,s of volts,,, trust me on this!!!!
it could easly kill you in one hit!!! just look at what a stun gun can do??
and thats only a small capacitor, whats inside your microwave is its very big brother! so if its growling at you, its about to go bang!
Posted on Oct 21, 2009
My '06 Honda Odyssey has gotten noisy recently.
If it is filled up to the "full hot" mark then you are okay, fluid wise. It almost sounds like once it gets warmed up, it starts running better. The "growling" noise (especially when turning) could be from it not getting enough fluid. Other than that, your power steering pump maybe on its last legs, and it is taking time to warm up before it starts pumping fluid correctly. Just make sure that you power steering resevoir is completely filled to the proper mark.
Aug 10, 2013 | Cars & Trucks
2005 Escape engine making growling sound
I believe it is the power take off unit (PTO).......
Can be a bit pricy to replace....
I hope this helps...
Apr 20, 2013 | 2005 Ford Escape
Agitator only moves a little bit and making noise
Most likely agitator dogs / gears are stripped out inside agitator. If it's a double action agitator where the top turns independently from the bottom, the top should turn one way and not the other. If top of agitator turns freely in either direction, then replace those dogs. If it's a single action agitator, then grooves that slide onto transmission shaft in agitator itself could be stripped out. If that's the case, replace agitator
Oct 27, 2017 | Kenmore Series 70 Washer Motor 387780
My '98 Taurus started making a clicking noise yesterday and seems to be running hot, the noise continues even when in park and increases with RPMs. I'm guessing that it might be the water pump, I don't see...
most likely you're right on it bad water pump, some times they don't always leak when bad. you can take radiator cap off while running to look @ see if it's circulating though thats a start
Aug 15, 2010 | 1998 Ford Taurus
May 10, 2009 | 2006 Pontiac Torrent
Recommendations:
Apr 11, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
Slow to spin and making a loud noise.
Control boards don't growl, the fry out and die. Sounds like a drive train problem to me. If it's a front load machine, the spindle/bearing assy. has gone to washer heaven. If it's a top load machine... could be the transmission, brake/clutch assy. or the tub bearings. In either case, if it's less than 5 years old, the drive system will be warrantied through the manufacturer. If you could provide a make and model number, I could narrow this down to a fine point.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
