Question about LG DLE5977 Electric Dryer
I need to purchase a heating element
  • Anonymous Mar 13, 2014
    Heating element needs to be replaced
    President:
  • LG Master
  • 1,922 Answers
You need to be more precise on the model # there are 3 different elements and prices vary widely, DLE5977--- need suffix letters or numbers at the end
Posted on Oct 01, 2009
My Crosley oven has a new element and timer and still will not heat up
It sounds like you need to replace the burner receptacle, in either the broiler or the bottom oven burner( heating element) or both. When it exploded it burned the contacts in the heating element.
Apr 11, 2014 | Ovens
Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
Oven won't heat, all burners work
I suggest that you remove the upper and lower heating elements to the oven, turn the oven switch to on, then use a good digital voltmeter, and check the plug that the lower heating element was in. If you have good (200 volts or more) then purchase and install new heating elements. Turn the oven switch to Broil setting and check the same way for the top heating element.
May 09, 2011 | Maytag Kitchen Ranges
Oven won't heat
The heating element may be worn out or loose. Are both the broil (upper) and bake (lower elements) failing to heat? If so, you will probably need to call a professional. If only one of the elements is failing to heat, it will need to be replaced. This is usually a simple matter of tugging firmly on the element and it will slip out of its housing. Once you purchase a replacement element you just plug in back into the housing. You can buy the elements at appliance parts stores. I would suggest calling an appliance parts store and asking them IF you can remove the element yourself. If they know they're about to make a sale, they don't mind giving you the information.
Nov 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Seat heater does not work. Control light is on but no heat. I think it needs a new heating element, is this hard to fix, where should I purchase it?
check you're fuse first don't change anything with out checking you're fuse and heating element connector.good luck
Aug 26, 2010 | 2004 Ford F250
Toaster no longer heats. Can I purchase the heating element and install myself?
mcdevito75 here, Chances are the heating elements are soldered in on the toaster and may take special tools to fix, if the heating elements sre burned out, maybe better to get another toaster.
Jun 19, 2010 | Dualit Vario 2 Slices Toaster
I need to replace heating element. where do i
www.partselect.com/Whirlpool-Range-Parts.htm - 4 hours ago
www.repairclinic.com › Whirlpool - 15 hours ago
Apr 04, 2010 | Whirlpool RF368LXKS Electric Kitchen Range
I have a Bosch WTL5410 dryer, which has no heat going to the otherwise functioning tumbler. Do you know where I could purchase another heating element and where I can get instructions regarding the...
Open front panel, remove heat exchanger and clean.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the switch. This is your reset button. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Mar 24, 2010 | Bosch Axxis WTL 5410 Electric Dryer
The dryer works but does not heat
Before you buy an expensive heating element change out the thermal fuse. It's only about 15 dollars for a fuse as opposed to around 100 dollars for a heating element. Both can be purchased at a appliance repair shop. The thermal fuse is usually located near the heating element housing and has two wires coming off of it. Make sure you unplug the dryer first though. If the thermal fuse if dead then your heating element will only heat for about a second or two at a time. The way to check this is to open up the dryer so you can see the heating element. While it's running watch it and it the heating element comes on and then turns off then the thermal fuse is bad. If it doesn't come on at all then the heating element is bad. Wait a good 5 minutes though before determining if the heating element isn't coming on. Sometimes it takes a bit before it engages. I hope this helps you and if you have any more questions feel free to ask me. Good luck.
Jan 08, 2009 | Whirlpool GEW9250 Electric Dryer
No heat
Check the resistance of the heating element (8 to 14 ohms). If ok, then check continuity of the overload devices attached to the heat element duct. If either one or both are open then replace ($14 for both). Dryer should heat.
If heat element is faulty, the part can be purchased at Sears/Kenmore Parts Center and swapped out ($45.00).
Provide your dryer model number and ask for the needed parts.
Unplug your dryer first before attempting any service work. Safety first and always!
Dec 19, 2008 | Whirlpool LER4634J Electric Dryer
LG DLE5977 Electric Dryer Logo
132 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
