Question about Canon PowerShot A590 IS Digital Camera
Every time I turn on camera I have to reset year,month, date, and time, I just bought the camera refurbished, otherwise everything is working just fine.
  • pj-j Dec 19, 2009
    I have to reset time and date each time I turn on Compaq N610c
    Scholar:
  • 157 Answers
Look for a tiny "button" type battery, in one of the compartments on the camera. That is there to store your settings. It is probably old, and needs replaced. If you put a new one in, and it doesn't work, take it back, or send it in to the manufacturer.
Posted on Oct 01, 2009
I have a kodak easy share M1073 and cannot figure out how to reset the date. I can turn the date stamp on and off but that's the only option I have.
It's important to set the date and time so that pictures and videos are organized by the date taken. The date and time procedure varies slightly between camera models, but generally:
  1. Turn on the camera.
  2. Press the Menu button.
    If you see a Setup tab, press the Right arrow button to highlight the Setup tab. If you don't see a Setup tab, press the Down arrow button to select Setup, then press the OK button.
  3. Press the Down arrow button to choose Date and Time (or similar), then press the OK button.
  4. Press the Right/Left arrow buttons to move between year, month, and date. Press (or press and hold) the Up/Down arrow buttons to scroll through the year, month, and date.
    Use the same procedure to set the time.
  5. When finished, press the OK button.
NOTE: If your KODAK Camera has a touchscreen, the same principles apply. Tap the Menu icon, Setup, then Date and Time (or similar).
Nov 03, 2010 | Kodak EasyShare M1073 IS Digital Camera
Doesn't remember time and date
Keith, it sounds like the camera internal battery for the memory is dead. Normally they will last several years, however I have seen them go bad in one to two years. These batteries are not easily replaced on the Kodak models and requires disassembling the camera and soldering in a new battery. My recommendation would be to keep good lithium or rechargeable batteries in the camera, removing them only when they need replacing, or if the camera is going to sit unused for more than a couple months.
Apr 21, 2010 | Kodak EasyShare C613 Digital Camera
My camera wants date enter each time it is turned
Whatever button you have to press after entering all the info, press it an extra time at the end.
Dec 18, 2009 | Canon PowerShot A540 Digital Camera
I turn my C913 on, and it turns right back off again. I put new batteries in it. Two days ago when I tried it, it said, you have changed the date and time, and then it turned off. It is only a couple...
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
The first number on your serial no. will indicate the year of production. If it shows 8 or 9 you might have a chance to order a warranty repair without your receipt. And if bought directly though KODAK you get free shipping :)
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 12, 2009 | Kodak EasyShare C913 Digital Camera
Need to reset time and date every time I turn on camera.
The backup battery needs to be replaced. This small button battery (CR1220) provides the power for your camera to 'remember' settings when you change or remove the AA batteries. Instructions for changing this battery are in the manual on page 191 (US version of manual).
You can view/download the manual here.
Sep 08, 2009 | Canon PowerShot SX100 IS Digital Camera
How do I set the time on an Olympus c-725 Camera?
Set the mode dial to AUTO, then press
the POWER switch to turn on the
camera.
● Be sure to take off the lens cap before
you turn the camera on (P. 27).
2 Press OK button.
● The top menu is displayed.
3 Press the up arrow button to select the clock.
4 Press
to select the date format.
● Select any one of the following formats:
D-M-Y (Day/Month/Year)
M-D-Y (Month/Day/Year)
Y-M-D (Year/Month/Day)
● This step and the following steps show the
procedure used when the date and time
settings are set to Y-M-D.
Press right arrow button move to the year (Y) setting.
6 Press
up or down arrow to set the year. When the year is set, press right arrow to move to the month (M) setting.
● Repeat this procedure until the date and time are completely set.
● To move back to the previous setting, press left arrow.
7 PressOk .
● For a more accurate setting, don't press until the clock hits 00 seconds. The
clock starts when you press the button.
8 To turn the camera off, press the POWER switch.
● The lens retracts.
Jan 06, 2009 | Olympus Camedia C-725 Digital Camera
Turns itself off every time I try to take a photo
I had a similar problem with my Cyber-shot S600. It just turned off every time I tried to take a photo. I bought a Sony recharger + batteries and it fixed the problem. Camera works fine and I'm impressed with the how long the batteries last between charges.
Jan 04, 2009 | Sony Cybershot S650 Digital Camera
Casio exilim z75
That just means that the internal battery may be fried just replace it. You can check your manual on how to do this as it is hard to describe.
Nov 29, 2008 | Casio Exilim EXZ75 Digital Camera
Date/TIme Screen ALWAYS appears when camera turned on.
You need to replace the lithium date/time battery. It is a CR1220 coin cell and it's replacement can be done using the instructions on page 109 of the advanced guide. If you don't have a copy you can get one here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=221&modelid=14905#DownloadDetailAct
Hope this helps, if it does please rate my solution.
Nov 16, 2008 | Canon PowerShot A520 Digital Camera
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Canon PowerShot A590 IS Digital Camera Logo
223 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
