Question about HP Photosmart C6180 All-In-One InkJet Printer
Ink System has failed. Unable to copy, receive faxes or print. Error Oxc19a0035
  • david_alexan Oct 01, 2009
    I have already attempted to reset the printer but the problem continues.
    This is the wrong model I have a Photosmart C6180.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The error Oxc19a0035 means ink system has failed. Try the following steps to troubleshoot the issue with the printer--
  • Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  • Open the cover of the product and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the product and wait for one minute.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Reconnect the USB cable, and try to print a print job from the computer.
    Try these steps if above steps doesn't resolve your issue---
· Press the On button to turn the printer off.
· Unplug the power cord from the back of the printer.
· Remove all the ink cartridges.
· Wait two minutes.
· Plug the power cord into the back of the printer.
· Press the On button to turn the printer on.
· Install the ink cartridges when prompted.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 01, 2009
Unfortunately, this error usually indicates something serious, a malfunction internally.
The resetting of the printer helps in about 10% of cases.
Please try the individual steps on this page very carefully in order to see if one can remove the error.
  • 3,741 Answers
First off let me tell you that you are not the only person facing this problem,there are many users facing this same exact problem.out of this 10 percent of users are able to solve the problem.and for your kind information this error problem comes only in your model brand of printer and not in all.so don't think hp is a bad product.hp is a very good product.but only in this model many users are facing the same problem. -------------- Unfortunately, this error usually indicates something serious, a malfunction internally.
You can read the official troubleshooting guide by clicking here.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il〈=he&rule=6783&product=3655608#reset_product
When on that page, click on "Any other error code", It will direct you to the part of the page to reset your product. I have found from experience that this resolves the problem about 10% of the time. If resetting the product does not work I would recommend going through each of the steps on the page and see if that works for you.
If it does not work, you will need to service the printer with HP.
this will help you.thanks.please do rate the solution.thank you for using fixya.keep updated.
Ink system failure
I have a message on my printer
Ink System Failure
ink system has failed -unable to copy, receive faxes,or print.
Refer to printer documentation
error Oxc19a0107
Feb 10, 2011 | HP Photosmart 3310 Printer
Ink system has failed. Unable to copy, receive
normally in this scenario the whole printer needs to be replaced..
Oct 22, 2009 | HP Photosmart 3310 Printer
Printer won't print
Try this Issue When trying to copy, print, or receive a fax, the following error message appears on the product control panel display. Ink System Failure. Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19aYYYY NOTE: The Y in the error message represents any digit, 0 - 9, or any character, A - F. Solution To resolve the issue, use the following steps. Step one: Remove the cartridges Make sure that the product is turned on and then disconnect the USB cable from the back of the product. Open the product cover and remove the cartridges. Close the cover and wait for a message to insert the cartridges to appear on the control panel display. Disconnect the power cord from the back of the product. Disconnect the power cord from the wall outlet and wait for one minute. Step two: Reinstall the cartridges Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on. Open the product cover and reinstall the cartridges. Close the cover and print a calibration page, if prompted. Print a self test report to make sure that the product can print. Reconnect the USB cable between the product and the computer. Try to print a document from an application on the computer.
Jun 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have a Ink System Failure.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Wait two minutes.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
hp photosmart c7288 all-in-one
ink system has failed unable to copy receive faxes or print refer to printer documentation error oxc19a0002
Nov 25, 2008 | Office Equipment & Supplies
Solution
Wait two minutes.
Jul 18, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
44 people viewed this question
Seeker5211
Seeker5211
