Question about Dryers
How to remove top panel of kenmore dryer model
How to remove top panel of kenmore electric dryer model #110.64962300 to replace door switch in front (purchased in 2003)
    President:
  • 1,776 Answers
Check the video at the following link and see if you find the information helpful in changing the door switch. Sure hope it does and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Oct 01, 2009
2 Suggested Answers
  • 108 Answers
SOURCE: Kenmore Elite dryer won't heat
if no heat at all unplug the dryer take off the vent take out the screws holding the back on there is a long oval shaped tube with two wires going into it there is a holding bracket holding it in place take out the screw unhook the wires take out a screw holds the heating coil in take out that screw inspect the heating coil for breaks it sounds like it is burned out if so replace if not it is probably the oval shaped thermostat on the tube i do hope that this was helpful then reverse the procedure, thank you.
Posted on Dec 31, 2009
How do i replace door switch on kenmore 11085088401
the switch is on the front panel. the top needs to be removed and then the front
Apr 27, 2014 | Kenmore Elite HE4 Electric Dryer
Dryer will not come on after setting timer and pushing start. No light when door is open.
Most likely the door switch is bad. Listen for a click when the door is just opened or closed. Noclick = bad door switch. The number you passed is NOT the model number. The model number will have 3 digits followed by a period and up to 8 more digiits after the period. i.e 110.xxxxyyyy or 110.Cxxx.yyy (examples only as it can be other numbers depending on the manufacturer.) There are other numbers starting with 417 and 665 also.
This is what I think your model number is: 11064672400
The door switch is item 41 below link: PN 3406107
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11064672400/0582/0151200/K0404036/00002?blt=06&prst=&shdMod=
Detailed view:
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/3406107/0026/110/Model-11064672400/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11064672400&subCompDesc=Cabinet%20parts&brandDesc=KENMORE&modelDesc=RESIDENTIAL-DRYER&blt=11
This manual will help you:
http://applianceassistant.com/pdf/27gasElectricDryers.pdf
The top has to be opened and the front panel taken lose and tipped out to change the door switch.
The manual is not straight forward as to the sequence of remofing things but you remove the top... open the toe panel loosen the lower front panel screws and then take out the 2 upper mounting screws for the front panel to gain acccess to the door switch. POWER OFF at the CB or dryer unplugged of course!
Thanks for choosing FixYa,
Kelly
Jun 25, 2011 | Kenmore 64672 Electric Dryer
How do you get the bottom panel under the door of the dryer off? It looks like there are clips of some sort there, but can't remove or move the clips enough to remove the door? please give step by step...
Unplug the dryer before attempting any repair works.
The bottom front panel is secured to bottom of the top front panel by two securing clips. Insert a flat-bladed screwdriver between the top front panel and the bottom front panel as shown then pry the panel out then lift it off the cabinet.
Install the bottom of the bottom front panel first when reinstalling then push the top back into position until the clips engage.
Aug 21, 2010 | Kenmore 62982 Electric Dryer
Replacing door light switch
The top will have to be removed and the front panel as well
Apr 30, 2010 | Kenmore 62062 Electric Dryer
My Kenmore Series 90 dryer won't run as it appears the door does not hit the actuator. It would appear either the door has moved to a lower position or the actuator has moved up into the dryer. May I ask...
The door switch or actuator is broken. A common problem. On most Kenmore dryers this is replace by lifting the top. Since you haven't given the whole model number I will discuss raising the top on the most common model.
If your model has a lint filter at the top the slide show below should show you how to raise the top.
Kenmore Dryer
Disconnect power to unit. Lift the cover from the lint filter or if yours is the one with a filter and cover together, remove the whole filter. You will see 2 screws under the cover/filter, remove them. Now, you will need a putty knife or a thin shafted straight screw driver to remove the top panel. Push the putty knife or screw driver to "pop" the front top clips. The top panel will hinge back towards the wall and can be left there. Just inside the top of the front panel, you will see 2 screws, remove them. You will see the wires for the door switch on the right side. *** the top of the front panel toward you to gain access to the switch for replacement.
Reverse process for reassembly. Good Luck
Sep 19, 2009 | Kenmore Dryers
Access to replace door switch
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out so you can replace the door switch and actuator assembly:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 04, 2009 | Dryers
How do I change the rollers on a Kenmore electric dryer 110.62932100? Thanks...Marie
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Remove the drum and the wheels will be easily aceeable.
Dec 26, 2008 | Kenmore 63942 Dryer
Replacing the belt on my kenmore electric dryer model # 110.8756.
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Get the drum out and clean out the dryer. Oil the wheels and idler. Replace the belt using this diagram . NOTE yours is lower right:
Dec 11, 2008 | Kenmore 62602 Electric Dryer
Install dryer belt
more information needed to specifcally match the model
however dryers are all similar so
generically, UNPLUG dryer
A:top mounted lint filter (kenmore maytag(New))
  • remove lint filter
  • remove screws in lint filter housing
  • with putty knife or other flat blade depress lock tabs at front corners of top body panel
  • tilt top panel up
  • remove screws 1/3 way down each side, remove door switch wires
  • remove front panel set aside
B:dryers with screws at bottom of front panel (maytag speedqueen)
  • remove screws from bottom of front panel
  • tilt front panel up
  • remove door switch wires
All
  • pull drum forward & out
  • examine drum felts, rollers, and slides for wear replace if worn
  • wrap new belt round drum at old wear marks
  • insert drum
  • wrap belt round motor pully
  • pull tensioner pulley hard to end of travel against spring
  • wrap belt round tensioner pulley
  • release tensioner
reassemble
Oct 19, 2008 | GE Dryers
Opening the front of Kenmore 62622 electric dryer
Remove the lint filter on top. remove the two screws. Use a butter knife or thin screw driver to pry up the front near the corners. Push in the clips when you pry. prop the top up and remove the wires to the door switch. If the front has 2 pieces open the bottom panel from the top and loosen but don't remove the two screws . From the top inside remove the two screws and lift the front off. If the front is one piece there will be clips holding the bottom just lift up.
Jun 22, 2008 | Kenmore 62622 Electric Dryer
Dryers Logo
653 people viewed this question
Top Dryers Experts
